Motor Lifting
Old Nov 25, 2001 | 10:23 PM
Rosati's Avatar
Rosati
Motor Lifting
Old Dec 28, 2001 | 02:28 PM
jcs1966's Avatar
jcs1966
Motor Lifting
I am getting ready to remove my "race motor" and take it to a mechanic to get a milder cam installed. I plan on removing the grill and hood and both front fenders. Then i want to unbolt the motor and remove it. My question is since it has headers installed where do I hook the chain to lift it? My next question is how do the inner fenders come off because I want to get some paint work done while the motor is out.
Old Dec 28, 2001 | 05:58 PM
Rosati's Avatar
Rosati
Motor Lifting
Your fender aprons are bolted to the core support and the fenders. Once the fender is out of the way, it's real easy to remove the aprons.
Krosati
[link:www.ford-trucks.com/user_gallery/displayalbum.php?&albumid=28|My User Gallery]
Visit my homepage at ClubFTE
[link:www.clubfte.com/users/krosati/index.html|My Homepage]
My friends say I'm too old to play with toys.
I need new friends
Old Dec 28, 2001 | 07:20 PM
6t6merc's Avatar
6t6merc
Motor Lifting
If you don't plan to disassemble the front end sheet metal, you might find it easier and faster to undo the whole clip in one piece. Then you can consider leaving the engine in the frame for the work.
Eric
Old Dec 28, 2001 | 08:27 PM
jowilker's Avatar
jowilker
Motor Lifting
jc, I agree with removing the clip. Remove the rad support, the inner fender and outer fender at the cab, with the hood off, the complete clip can be removed. You will have to unplug the wiring also.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Dec 29, 2001 | 12:24 AM
LxMan1's Avatar
LxMan1
Motor Lifting
The easiest way to lift the motor is to buy a carb plate that bolts to the intake manifold where a 4bbl carb. bolts up. Or you can find a couple of longer than stock grade 8 bolts and use one intake bolt hole on opposite sides of the engine . One on the front right and one on the left rear or visa-versa. If you are pulling the trans too, center your hook on the hoist chain so that the rear of the engine tilts down,this will make it eaisier to get the tranny out past the firewall.
Old Dec 31, 2001 | 02:55 PM
jcs1966's Avatar
jcs1966
Motor Lifting
So you are saying a couple of bolts will be O.K. to lift the engine???
Is it really that simple!?!?!?!
I thought maybe somekind of sling or cradle was needed.
The only motor I every say lifted had chains running to the exhaust manifolds and my motor has headers.
Old Dec 31, 2001 | 03:39 PM
66worktruck's Avatar
66worktruck
Motor Lifting
3/16th's or 1/4" steel plate with carbueretor bolt pattern & a SECURELY welded hook should do the trick for you.
Old Jan 1, 2002 | 01:12 AM
LxMan1's Avatar
LxMan1
Motor Lifting
I've pulled many a motor with 2 bolts. As long as they are grade8 . I have never dropped one yet. Most of the prebuilt carb plates, available at most speed shops and mail order like Summit, actually have 3 hook holes so that you can get the proper angle to get it out of the truck. I usually use the 2 bolt method, you can vary the angle by where you put the hoist hook on the chain bolted to the motor.
Old Jan 1, 2002 | 08:40 PM
66ranger's Avatar
66ranger
Motor Lifting
Biggest problem I found when trying to disassemble the sheetmetal on these trucks is the blind nuts breaking off when I try to remove the bolts. Be carefull, especially if you try to remove your hood hindges from the cowl, if any of the blind nuts break off from behind, there is no way to repair this unless you cut open the cowl and reweld it together when done!! I have always had good luck using opposite corner head bolts, of proper grade of course, to remove the block. Check your clearence if doing this in your garage, your truck will raise up once the engine is lifted up from the frame..
Old Jan 12, 2002 | 12:01 AM
zzslayer1's Avatar
zzslayer1
Motor Lifting
This may sound kind of stupid but remember that you are pulling the motor out of a truck that is higher then a car by far so the angle you use to pull the motor is critical. Using two bolts and a chain and then sliding the engine is a good method but if the angle gets to steep then life gets exciting fast. Most u-haul places have a double adjusting chain that can be used to adjust the center as well as the rear and front height of your chain so be careful it only weights about 300+ pounds he he
Old Jan 12, 2002 | 04:49 AM
jowilker's Avatar
jowilker
Motor Lifting
Keith, If he has a FE 352/390 it will weigh more than twice that.
John
jowilker email me
Old Feb 15, 2002 | 01:37 PM
Trail_Rider's Avatar
Trail_Rider
Motor Lifting
I usually use an existing top bellhousing bolt at the back and another bolt in the front of one of the heads.
Trail Rider
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
