Ignition problem, no key needed
Old Jul 18, 2001 | 01:21 AM
canadianfordman's Avatar
canadianfordman
So I was going to move my 1986 f150 4x4 and I didn't realize the keys weren't in the ignition when I turned it anyway and voala the thing started up! How can I fix this? How easy is it to change the ignition over, I have another 86 f150 parts truck could I switch be possible?
Thanks
C'Fordman
Old Jul 18, 2001 | 03:15 AM
RubberDuck's Avatar
RubberDuck
You bet the swap is easy, just turn the key to the on position,and there should be a small hole underneath that you can put a small allen wrench in to depress a small keeper and the whole mechanism should come right out. And the other one should just pop right in. At least that's the way it goes on my truck. Yours may be a littl different.
RubberDuck
Old Jul 19, 2001 | 01:22 AM
canadianfordman
Perfect, thanks a lot I will try it tomorrow, What year is your truck?
Thanks,
Canadianfordman
Old Jul 20, 2001 | 05:45 PM
82F100SWB's Avatar
82F100SWB
If you don't have tilt steering, you have to pull the steering wheel, but, other than that, it's basically the same, depress the retaining pin and pull it out.
Evan MacDonald
82 F100 FlareSide 2wd
HD 300-6 9.5:1 CR
Clifford 270H cam
Hedman Hedder
SBC valved 66 240 head
Headlight Relays - Delanty Style
NP435(6.69 low)
3.55 Geared ARB'd 9"
31x10.50/15 Cooper Discoverer LT's
Old Jul 21, 2001 | 05:12 AM
canadianfordman
I got the one out of the parts truck no problem because it has tilt but the other is a different story. I will see what I can do with that!
Thanks guys
Old Jul 30, 2001 | 11:16 PM
tdk's Avatar
tdk
I had the same problem with the key switch on my 81 F150 and found that a little WD 40 sprayed in the key hole freed up the tumblers.
Old Jul 31, 2001 | 01:24 AM
canadianfordman
Good thinkin, Thanks
Old Jul 31, 2001 | 08:19 AM
82F150's Avatar
82F150
brosko80
Sep 27, 2023 12:15 PM
khadma
1997 - 2003 F150
Mar 31, 2013 11:34 PM
89MustangGX
18
Mar 1, 2007 03:46 PM
JDPoore
Dec 26, 2004 07:14 PM
