engine swap
Old Jul 29, 2001 | 09:54 AM
Boss300's Avatar
Boss300
engine swap
I got an old '81 ford f100 that i plan to make a mud truck. My question is how hard would it be to swap a 360 FE motor into this truck. Has anyone ever attempted this? Thanks
Old Jul 29, 2001 | 01:22 PM
cbwarrior's Avatar
cbwarrior
engine swap
Old Jul 29, 2001 | 10:00 PM
sweet82's Avatar
sweet82
engine swap
the fe is a big block and needs a big block bolt pattern tranny and mounts fabing some engine mounts is not that hard what drive train do you have in right now
Rodney
LFLS
Old Jul 30, 2001 | 01:42 PM
mavman's Avatar
mavman
engine swap
why the h*** would anyone put a 360 in something like that when you can put a 460 in just as easy? Nothing wrong with a 360 other than they are huge, heavy gutless turds (good for a work truck!). Unless you already have a 360, go with one of the other big blocks, parts are much cheaper and plentiful! Just my $.02
Old Jul 31, 2001 | 08:29 AM
82F150's Avatar
82F150
engine swap
The Fe block is a pain but as already mentioned a possible swap. I found that if original engine is 302W, a 351W, or Lincoln 400 will bolt right in to a C6 setup. If you want to go to 460, you will need new frame to engine mount spacers which can be obtained from the salvage yard from a 80-86 F-Series or Bronco with the same engine/transmission you are attempting to convert. You will also want the exhaust manifolds from the orginal setup as well.
