help please
Old Mar 2, 2005 | 01:09 PM
stumpknockerr's Avatar
stumpknockerr
Exclamation help please
i have a 351m v8 and i am experiencing problems. My truck was running fine about 2 days ago, but all of the sudden I am ecperiencing whats seems to be a lack of torque and it is having a hard time changing gears. I just had the whole tranny rebuilt and dont suspect any major problems there. There is a small amount of oil (or perhaps trans. fluid) leaking around the converter drain plug area. Is it a compression problem?
Old Mar 2, 2005 | 03:10 PM
53fatfndr's Avatar
53fatfndr
If it was running fine before you had the tranny rebuilt, I would call up the place that rebuilt the tranny and see what they have to say.
Old Mar 2, 2005 | 08:47 PM
hdgapeach's Avatar
hdgapeach
I'd go back to the tranny shop and let them look at it if there's any sort of warranty with the rebuild. Possible just the modulator valve vacuum hose came off, but you never know.
Old Mar 2, 2005 | 11:34 PM
stumpknockerr
thanx for relplying
hey thanx for the replies--I'm a novice mechanic so bare with me-- the truck changes gears at a high rpm ---i'll have the gas pedal all the way to the floor---
can this have anything to do with the engine--I ask because the engine has a hard time idling (I usually have to continue gas it to keep it running)I was kinda suspecting compression troubles before I actually pulled out of my drive way and encountered the tranny problem---once again thanx for your help---
---and my tranny is under warranty-it has a 1 year warranty and it was fixed about 3 months ago --no problems at all until now.I am avoiding calling the guy because he has not been very cooperative in the past.
Old Mar 3, 2005 | 01:02 AM
fmc400's Avatar
fmc400
MSEE
The shifts are controlled by the modulator valve. The modulator valve hooks to manifold vacuum, so if there is a leak in the line, that could explain the rough idle.
Old Mar 3, 2005 | 06:59 PM
mark a.'s Avatar
mark a.
1 year warrenty. It's his baby for 1 year. Tell him not to cry about it, just fix it........... that was the deal you paid for.
Old Mar 3, 2005 | 07:31 PM
hdgapeach's Avatar
hdgapeach
No shifting + rough idling = vacuum leak 'cause the modulator's vacuum line is off.
Old Mar 4, 2005 | 12:34 AM
stumpknockerr
thanx
hey thanx a bunch for your gelp guys---yeah i contacted him and he said he'll look at it for free--hopefully that will work
firebug
Jun 21, 2010 07:00 PM
mblanken881
Jan 10, 2009 07:58 PM
smolicht
May 9, 2008 08:14 AM
CougarJohn
Oil & Lubrication
26
May 17, 2004 11:17 AM
Mgles50117
Sep 25, 2001 11:15 PM
