1960 Door Hinges
Old Mar 2, 2005 | 11:01 AM
mcdonaldm's Avatar
mcdonaldm
1960 Door Hinges
Okay, this might be dumb question, but here goes anyway.
Are the door hinges on a 1960 F100 all the same or are they different top and bottom.
I can't really see any difference in the design, but then again I took mine apart to sb and put new pins and bushings in and might not of got them back togather right.
The problem is that once installed and the hinges adjusted all the way out in the pockets, the door is still not far enough out at the front. i know i can add shims to bring it out, but when I took truck apart there was no shims.
Any help would be great.
thanks
Mike
Old Mar 2, 2005 | 01:36 PM
kooper909's Avatar
kooper909
The top hinges and bottom hinges are interchangeable. The driver-side and passenger-side hinges aren't, though, since the two ends of the hinge pin aren't identical.
PeeVee
1947 and Older Ford Trucks
Sep 22, 2011 01:44 PM
73FOMO
Feb 9, 2009 08:43 AM
BGL
1978 - 1996 Big Bronco
May 31, 2005 09:44 PM
calbear
Oct 21, 2004 11:57 AM
special k
Dec 25, 2000 10:48 AM
