Upper Door Hinges...
Old Feb 8, 2009 | 09:22 PM
73FOMO's Avatar
73FOMO
Quick question. I have had this truck apart for so long...and I had 3 doors and all the hinges apart picking through the least worn out parts for rebuilding. I know the lower hinges are universal can be used on either side, but is there just one upper hinge that is used on both sides? I went to put my doors back on today and noticed the 2 upper hinges were identical. All of the holes are in the same place and they can be flipped so I went ahead and flipped the one on the drivers side. On one side the upper hinge door "rollers", or opening stops are on the top side of the hinge, and on the other they are on the bottom. The door works fine, but I just couldn't remember it being that way?
Old Feb 8, 2009 | 10:01 PM
Alvin in AZ's Avatar
Alvin in AZ
Yep, that's the way they are and not just on Fords neither.
You asking that is a bad sign tho. ;)
You haven't been oiling your hinges have you? ;)
I have a squirt can with STP in it.
(the one thing I've found the dangged stuff good for)
Alvin in AZ
Old Feb 9, 2009 | 08:37 AM
73FOMO's Avatar
73FOMO
Thanks Alvin...actually they are in great shape now. I thought they were reversible, "the same" I just couldn't remember one side being upside down. I replaced the hinge pins and the rollers work fine. They are smooth as glass. It's been two and half years with doors off as I started rebuilding this truck and had to put on hold because I sold my house and had to build a new house first! I am slowly beginning to make progress again.
Old Feb 9, 2009 | 08:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 F100/350 Door Hinges / 1978/79 Bronco
2) D3TZ1022800A .. Right/Left Upper Door Hinge / Obsolete
DEALER AUTO PARTS in Cincinnati OH has THREE: 800-543-4959
MILLER OBSOLETE PARTS has ONE: 800-546-7278
WESLEY OBSOLETE PARTS in Liberty KY has ONE: 606-787-5293
HAVEN FORD SALES in Haven KS has ONE: 800-748-7803
2) D3TZ1022810A .. Right/Left Lower Door Hinge / Obsolete
DEALER AUTO PARTS has THREE.
MILLER OBSOLETE PARTS has TWO.
CARPENTER OBSOLETE PARTS in Concord NC has THREE: 704-786-8139
MATLOCK FORD-MERCURY in Franklin IN has TWO.
Fix
1947 and Older Ford Trucks
26
May 11, 2012 01:45 PM
Roamer
May 8, 2009 07:46 PM
Roamer
'80-'86 FAQs (Frequently Asked Questions)
syncback
May 13, 2006 09:56 PM
dgrimm1986
Sep 23, 2005 11:14 AM
