Need help with IAT sensor
Old Mar 1, 2005 | 12:53 PM
will-ford's Avatar
will-ford
Hey guys, I have a 2004 ford f-150 am i am having trouble finding my iat sensor. i think i might have found it in the intake tube, but i couldnt get it out. if thats it, it looks like i need some special tool to get to it. is this the right thing? Help please
Old Mar 1, 2005 | 05:04 PM
DonsFx4's Avatar
DonsFx4
will-ford...which engine do you have??
On the 4.6L, it should be in the intake tube (connector is underneath).
On the 5.4L, it should be up behind the air filter box.
Don't know if you need special tools or not, but do a search in the 5.4 modular engine forum and you may have all the instructions spelled out for you.
Old May 3, 2008 | 07:52 PM
jerow's Avatar
jerow
Performance Chip Question
I have a 2004 F150. I am trying to install a 2 wire chip to the IAT sensor. Where is the IAT sensor and if it is the plug coming out of the CTS, which wires do I hook the chip to?
Old May 4, 2008 | 01:45 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
DO NOT INSTALL THAT RESISTOR CHIP. Those things are cheap $0.01 parts. That thing will fail down the road and short out your IAT sensor. It "shorts" the sensor and tricks the PCM to run rich. I know it's cheap, but you're just asking for broke stuff
southern hunter56
Mar 23, 2011 04:20 PM
94stroker
Mar 21, 2011 05:00 PM
Adamjr
Jun 12, 2010 09:45 AM
itsaford
May 20, 2010 12:58 AM
firefighter525
1983 - 2012 Ranger & B-Series
Mar 13, 2003 06:12 AM
