coolant reading
Old Feb 27, 2005 | 09:16 PM
jcab's Avatar
jcab
Smile coolant reading
Just checked coolant today with fleetguard test strips, and got a reading of 2.0 as far as I could determine. It says I should change coolant filter, and add additive at next oil change. Should I just drain and refill with new filter, coolant and additive?? 1.5 to 3.0 is within normal range. I don't know where the coolant filter is either. I have a 97 crewcab with 88,000 miles. Please advise. Jeff
Old Feb 28, 2005 | 07:49 PM
jcab's Avatar
jcab
Nobody has a clue on this one???? C'mon I'am sure you guys know what should be done? Thanks jeff
Old Mar 1, 2005 | 05:10 AM
rockyrider's Avatar
rockyrider
Unless you had done some mods you won't have a coolant filter, if you do it will be obvious.
How long has it been since you did flush? If it's time for flush just do that and add DCA as required to get proper reading.
Do a search on this form as well as DIESELSTOP, you need to make sure you get correct coolant, stay away from silicons. Hope this helps you.
johnsonjf
Jun 14, 2014 01:35 PM
cornstar6207
May 9, 2014 10:34 AM
amd_038
Aug 20, 2011 08:03 PM
mjtpolice76
69
Jan 15, 2006 01:43 AM
Beachbumcook
Sep 20, 2005 09:31 AM
