ranger air bag code 19 ?
Old Feb 27, 2005 | 02:15 PM
mach's Avatar
mach
Question ranger air bag code 19 ?
Hey every one I'm a new guy. stumbled on to this great site.
I had a little fender bender to the right front of my 98 ranger 2 wd. the air bag light is now flashing a code 19. does any one know what 19 means or how I can find out.? The air bag did not deploy. I know sometimes codes can be cleared with out repairs and sometimes not.any info will be appreciated.
Old Feb 27, 2005 | 03:45 PM
Dave257's Avatar
Dave257
You will need to replace the RCM module. $$
Dave
Here are the codes for Air Bag faults. When frist started the dash light will blink the two digit code before it comes on permently.
Continuous (blinks no code)
RCM Disconnected or Inoperative, Loss of Battery Feed, or Loss of
Signal Ground
15
Incorrect Vehicle ID
15
Driver Air Bag Circuit Shorted To
Ground
15
Battery Or Ignition
16
Passenger Air Bag Circuit Shorted
To Ground
16
To Battery Or Ignition
17
Air Bag Tone Warning Indicator
Circuit Shorted to Ground or Open
17
Driver Pretensioner Circuit
Shorted To Battery Or Ignition
17
Shorted To Ground
18
Passenger Pretensioner Circuit
18
Shorted To Ground
18
Circuit Short to Battery or
Ignition
19
RCM Crash Data Memory Full
21
RCM Bracket Ground Resistance
High
24
RCM Is Faulted
25
Passenger Air Bag Deactivation
(PAD) Switch Fault
27
(PAD) Warning Lamp Inoperative
27
(PAD) Warning Lamp Shorted to
Battery
32
Driver Air Bag Circuit Resistance
High
33
Resistance High
34
Low
35
Resistance Low
46
Resistance High
46
Resistance Low
47
Resistance High
47
Resistance Low
Old Feb 27, 2005 | 04:21 PM
mach's Avatar
mach
thanks for the code chart. I want to clearify that I get the flashing code 19 5 times then the light stays lit.
Are you saying that code 19 = rcm crash data memory is full, there for the rcm must be replaced? or did you think I ment the light keeps flashing continous?
I would like to try to clear it before I start replacing parts if possible, thanks again for the response!
Old Feb 27, 2005 | 05:09 PM
Dave257's Avatar
Dave257
The RCM fault 19 can't be reset, it will need to be replaced. As the checkout goes to each error code in order it will stop at any error it finds. It will not progress to the next code until that error is fixed. So you may have more errors comming as you are only at 19. good luck.
Dave
Old Feb 28, 2005 | 08:25 AM
mach's Avatar
mach
thanks Dave.
gsmullin
6.4L Power Stroke Diesel
Aug 19, 2016 09:17 AM
Nitro Blazer
Feb 28, 2012 01:15 PM
ddruma14
Electrical Systems/Wiring
Jul 25, 2009 07:48 PM
h2omotorsports
Nov 14, 2008 04:44 PM
AlexTG
1978 - 1996 Big Bronco
Nov 22, 2005 05:45 PM
