Air bag code 32
Old Sep 6, 2008 | 10:32 PM
h2omotorsports's Avatar
h2omotorsports
Air bag code 32
I keep on getting air bag code 32. I think it is drivers air bag resistance low. I was wondering if any one has ran into this and what the solution may be. Thanks for the help
Jon
Old Sep 7, 2008 | 09:37 PM
F350-6's Avatar
F350-6
Lamp Fault Code 32, DTC B1932 Driver Air Bag Resistance High
The pinpoint test calls for using a scanner to check for other codes, and check for the 1932 code along the way as you check things out. You could disconnect the batteries and check the wiring for continuity to see if there is a problem with the wires or clockspring, but you need to be careful poking metal prongs in the air bag connectors.
Old Nov 14, 2008 | 01:39 PM
Dave Tyler's Avatar
Dave Tyler
Air Bag Code 32
Did you ever fix your air bag code 32? Have a 99 f250 PSD. Dave
Old Nov 14, 2008 | 02:57 PM
h2omotorsports
No never did. I would rather not mess with the airbag system but if anyone else knows what the solution would be that would be great.
Old Nov 14, 2008 | 03:22 PM
Dave Tyler's Avatar
Dave Tyler
Smile Air Bag Code 32
I have seached the threads but really not have found the fix. there are fixes to alot of the codes. Just not have seen the fix for the code 32. Thanks for responding. Dave
Old Nov 14, 2008 | 03:48 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
look on your passenger side airbag shutt off lamp see if when you turn the key it should light up if its in on position, mine does it sometimes, and i know its a connector or a bulb itself.
Old Nov 14, 2008 | 04:44 PM
Action4478's Avatar
Action4478
Heres a start ...
Most likely need a clock spring ....
Remember this Chris ?....
Click me....
Gene W
Oct 29, 2013 10:03 AM
snorindad
1983 - 2012 Ranger & B-Series
May 16, 2012 07:25 PM
ehgeeray
Jun 6, 2010 07:34 PM
AlexTG
1978 - 1996 Big Bronco
Nov 22, 2005 05:45 PM
Xanderificus
Aerostar
Nov 27, 2003 04:05 PM
