Air bag code 51 on 95 Bronco.... What to look for first?
I posted up earlier about a list of codes for this problem. Found the code, found that it has to do with the internal thermal fuse blowing in the control unit.
This unit is under the dash correct?
Where is the most common place to find a short in the system? Would I be smart to start looking in the seat belt area? Since the seat belts will be the most likely part to be worn and I know they have a wiring harness in them for the indicator and I imagine for the airbag system.
This is the main part of what I have found on everything I have clicked...
Note:
The air bag diagnostic monitor contains an internal thermal fuse that is not serviceable. The thermal fuse is controlled by a computer inside the air bag diagnostic monitor. The computer will blow the thermal fuse whenever a short on the deployment circuits occurs. The thermal fuse does not blow because of excessive current flowing through it. DO NOT attempt to jumper out the thermal fuse with a circuit breaker or any other type of fuse.
Note:
DO NOT install a new air bag diagnostic monitor until the short has been located and corrected. If a short to ground has not been located and corrected, then the short to ground is intermittent and IS NOT PRESENT AT THIS TIME. Installing a new air bag diagnostic monitor with an intermittent short in the system will result in blown air bag diagnostic monitors and repeat repairs.
The air bag diagnostic monitor measures the voltages at the diagnostic monitor connector pins. When certain air bag deployment wires are shorted to ground (heavy lines illustrated in the schematic below), the supplemental air bag restraint system may become susceptible to unwanted deployment of the air bag(s). The air bag diagnostic monitor senses a short to ground on any of these circuits and helps prevent unwanted air bag deployant by blowing the diagnostic monitor thermal fuse. Blowing this fuse removes all power (battery and back-up power) from the air bag deployment circuits. While the short to ground exists, the monitor will flash code 13. If the short to ground is intermittent and temporarily corrects itself, the air bag diagnostic monitor will flash code 51.
Any help is greatly appreciated! Thanks!
Note:
Note:
The following users liked this post:
ham bone
09-01-2020 08:52 AM
