6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Air Bags
Old Aug 14, 2016 | 02:52 PM
gsmullin's Avatar
gsmullin
Air Bags
I am going to be pulling a large fifth wheel and was thinking of air bags. Does anyone know if i can have air bags with a lift kit?
Old Aug 14, 2016 | 09:17 PM
jimh425's Avatar
jimh425
I suppose it depends on how much it is lifted, but Firestone makes "lift spacers".
Old Aug 14, 2016 | 09:32 PM
eberlestock's Avatar
eberlestock
Should work but depends on the bags. I had a set installed in my 06 with a 6" lift. I sold the truck shortly after and pulled them out. I just went back to the shop that installed them the first time and had them re-installed on my new rig with an 8" lift. They added a small block between the bags and the spring and everything fit just fine.
Old Aug 19, 2016 | 08:08 AM
ginomachino's Avatar
ginomachino
my bags had multiple bolt holes on the base plate (which mounts to the axle) for height adjustments. I think the one I got was good for up to 4 inches. Ride Rite 2550. But I do not have a 5th wheel hitch and my bags mounted on the inside of the frame, and with a 5th wheel hitch, your bags will mount on top of your leaf spring. Please correct me if I'm wrong...
Old Aug 19, 2016 | 09:17 AM
eberlestock
I have pac brake air bags and they mount on top of the leaf spring.
traveldawg
Aug 20, 2018 10:21 PM
navyjuice
Nov 28, 2016 04:24 PM
stangman05gt
2009 - 2014 F150
Aug 21, 2011 02:14 AM
doberman
Feb 14, 2008 08:18 PM
sismo817
May 13, 2003 09:11 PM
