Wicked Wheel
Old Feb 26, 2005 | 10:05 PM
kawika's Avatar
kawika
Wicked Wheel
For those of you that have replaced their turbo compressor wheel with the Wicked Wheel, I was wondering where you got the torque settings for all the turbo bolts. I just ordered me a wicked wheel and 4" exhaust and want to have as much information as possible. I do not have the luxury of having mechanically inclined friends and will be doing this by myself, so the more I know the easier it will be. I want to make sure that the turbo bolts back up and not leak or break a bolt (or the turbo) tightening them. I’ve heard that a few of the bolts are in an area that’s hard to reach. What were the average times it took you to complete the install? What are some of the pitfalls? Any hints, or things to do, to make it easier? I’ve wrenched on my trucks when I was younger, before they had computers for brains. Now I only do the easy stuff. I can’t afford someone to do this for me, so I’ll just take my time and do it right the first time. Any and all posts will be appreciated, thanks.
Old Feb 26, 2005 | 11:08 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Click here for a how to article.
Old Feb 27, 2005 | 03:53 PM
kawika's Avatar
kawika
Thanks Cookie,
Printed me a copy of the procedures, Seems straight forward. I am still searching for the torque settings for all the bolts and Marmon clamps. I would hate to blow off a boot after I reassemble it and drive away. Will have to go to Autozone to see if I can find it in their library of Manuals. Thanks...
Old Feb 27, 2005 | 09:26 PM
cookie88's Avatar
cookie88
FTE Emeritus
You should post them if you find them. They are not in the Ford service manual....prolly have to go through Garrett to find them.
The only place you have to be careful on the torque is the clamps that hold the orange boots to the engine's intakes, the intakes are stamped steel and it is possible to crush them. The housing bolts, if I remember correctly, are a 1/4" by 24 with a 5/16" head, which would make the proper torque 70-85 in.lbs. The wheel itself needs only snugged up, it's rotation will make it self torque....if there is such a thing.
Old Feb 28, 2005 | 12:33 PM
allisonta's Avatar
allisonta
Just put a new compressor wheel on my 01, directions stated 100 in/lbsfor the new wheel.
Old Feb 28, 2005 | 07:58 PM
kawika's Avatar
kawika
Once I get most of the specifications on the garrett turbo and the other bolts associated with the replacement, I will post it in this thread. I found only one email for the garrett turbo and am waiting for a reply.
Old Feb 28, 2005 | 08:58 PM
18vtx00's Avatar
18vtx00
Smile
it is very hard to get @ the 2 rear bolts on the pedistall.
10mm swivel socket a must.
the bolts have an 8mm 12 point head. and 8 X 1.25mm pitch. mine we rusted in and had to heat them and use vise grips. then i used new bolts w/ 6mm allens. much better this way.
do not forget new o-rings on the pedistall!!!
good luck. you will need the tool i described. no swivels..buy them it cannot be done w/ out them.
i have them @ work,forgot the swivels. so luckily my neighbor is a MAC tool guy. on a sunday morning i was at his door.lol lol
Old Feb 28, 2005 | 09:03 PM
18vtx00's Avatar
18vtx00
now i wish you had posted the year of your truck in the post.
mine is a 1996 and the pedistall must come off.
so i guess yours is a little different.
Old Feb 28, 2005 | 09:49 PM
Rancha9's Avatar
Rancha9
From a Haynes manual:
Turbo to pedestal: 18 ft lbs
Pedestal to engine: 18 ft lbs
These are the #'s I used to do mine, and have had no problems since. I don't have a # for the compressor wheel, as Haynes says you shouldn't be taking it apart (where's the fun in that!)
Old Mar 4, 2005 | 09:41 PM
kawika's Avatar
kawika
I finally received an email back from the Garrett Rep with the torque setting for the turbo housing. This is what he had to say.
> everything on the GTP38's and the TP38's torque to 200 inch pounds except
> for the comp. wheel it torques to 100 inch pounds. Let them know that they
> need to use loc-tite on the turbine housing, but never put loc-tite on the
> comp. wheel. I hope this helps :-)<O></O>
<O></O>
I also found some <YR 2001>drawings and part number and have added the torque settings that I have found so far.
Old Mar 4, 2005 | 09:49 PM
kawika's Avatar
kawika
The above drawings was for a 2001. I think its good for 1999 - 2003, something like that. For some reason my update did not post.
Wicked Endings
Jan 16, 2011 10:48 AM
Storm
Oct 8, 2007 05:20 PM
jtharvey
28
Feb 26, 2006 08:57 PM
riceman
26
Feb 21, 2006 11:22 PM
hink10
19
Nov 5, 2005 06:43 AM
