Wicked Wheel Install Lessons Learned
Old Dec 21, 2005 | 01:13 PM
riceman's Avatar
riceman
Finally finished up my wicked wheel install and thought I’d lend some advice for those of you thinking of the install. I have some good before and after boost numbers. The instructions from Black Cloud, FTE and Dieselsite.com where all very informative. The instructions call for you to set the turbo on the pedestal and get everything started before tightening up anything. I did this and got the clamp coming up from the manifold started a little too much. This caused the turbo not to seat properly on the pedestal and when you torque the mounting bolts to 18 ft lbs, it’s never really flat against the pedestal. Talking about a nice oil leak when you fire it up. Next the clamp coming up from the manifold is tricky. There are 2 lips on the turbo side. Make sure you only get the clamp around the first one and not on the second one. This will cause a nice exhaust leak and cause low boost. The best way I found was to go ahead and mount the turbo to the pedestal and torque to 18 ft lbs, then do the clamps, but already have the clamps around the pipes.
Instruction don’t call for you to remove the drivers side intercooler pipe. I recommend you do so you can check for chaffing from the wire covers. Mine had a nice wear mark from the battery cable wire. None of the chaffing had gone through the tube yet but left unattended it would have. I fixed all the wires so they won’t rub now.
<O
Now for the real numbers. My truck (99.5 F250) has a stock program, only mods are the Napa Filter and Muffler Delete Pipe.
Boost comes up much faster with the wicked wheel.
Stock wheel or Wicked Wheel, boost never goes above 18 psi with hard acceleration.
Stock wheel at 70 mph and 2k rpms gives you 4 to 5 psi
Wicked wheel with the same conditions I see 5 to 6 psi<O
Stock wheel causes it to down shift a lot more often, the wicked wheel causes the boost to come up so fast the truck doesn’t down shift as often on the freeway. It just goes. <O
The whistle is present but not all that loud. With the radio on you can’t even hear it. Window down it does sound nice though. <O
Just some thoughts that might help someone before they tackle this project.<O
Old Dec 21, 2005 | 01:51 PM
sandlapper's Avatar
sandlapper
Thanks for the info. I'm doing mine next weekend if I have time. Did you change out the o-rings?
Old Dec 21, 2005 | 02:16 PM
PSNut's Avatar
PSNut
When i did my WW i didn't change out the "o" rings and got lucky with no leaks.
Biggest problem was getting the frozen "v" clamp off the up pipe , on re-install i used lots of anti-sieze compound...practically painted it wit it...LOL!...
figured i'll probably be pulling this thing off again. Not particually comfortable laying across the engine too.
Old Dec 21, 2005 | 02:38 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Never goes over 18psi? When I put the go pedal down, mine easily goes to 24psi until I defuel (around 25psi)and she is pullin hard all the way to 24psi. Hey guys is 18psi normal or do I have issues?
Old Dec 21, 2005 | 02:58 PM
edub32's Avatar
edub32
Which tune are you using? He's running a stock program. Adding fuel (via programmer or chip) will add a little boost....
Old Dec 21, 2005 | 07:11 PM
riceman's Avatar
riceman
I did replace both sets of o-rings, best thing I did is follow the advice of buying a moving blanket and lay on that while working on the truck. Made it much easier and cost $14.00 at home depot. I bought my wicked wheel from dieselsite.com and they offer the o-rings with the kit (extra 7 bucks I think). They only provide one set of o-rings. I went to ford and got the second set for the pedestal ($5). Best way is to take the turbo out and put it on the bench to work on it. I couldn't imagine doing it in the truck as some instructions call for. I figured if I'm that far in I should replace all the o-rings. To tell you the truth, I ended up taking the turbo out 3 times before I was happy with everything. In the end I could have the turbo out and re-installed in about 2 hours. To get those 2 exhaust clamps off the first time, I advise that you take the t-bolt and nut off. Then tap with a small hammer and it will pop loose.
Old Dec 21, 2005 | 07:37 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
yes, i learned the hard way by NOT replacing the o-rings. i started it up and let it idle, and within a minute, i had two gallons all over the engine and on the floor. nice oil leak. so i had to do the whole thing over again. now i have the procedure down good.
an easy way to get the "frozen" up pipe clamp off, is to take a small slotted screwdriver and jab it in the area between the edge of the clamp section (there are three) and the actual turbo flange. then pry up on the handle and it will pop the section off quite easily. do this to the opposite side, and it will enable the bottom section to come off fairly easy.
Old Dec 21, 2005 | 07:40 PM
PSNut's Avatar
PSNut
Yeah i agree, that's what i did to get those pesky "v" clamps off.
Old Feb 20, 2006 | 03:04 PM
Joe98684's Avatar
Joe98684
<O
Am I to understand that you only torque the 2 bolts from the turbo to the pedestal to 18 ft lbs?? This doesn't seem like much.
Old Feb 20, 2006 | 03:23 PM
bigpowerstroke's Avatar
bigpowerstroke
I have installed the ww on my truck by pulling the turbo out just like the instructions, I installed one on my brother's truck while leaving the turbo on the truck. This was much easier.
Old Feb 20, 2006 | 03:26 PM
turbostroke's Avatar
turbostroke
On a completely stock engine 18-19 psi boost is a good all-around average number.
Old Feb 20, 2006 | 03:28 PM
PSNut's Avatar
PSNut
I agree totally.
Old Feb 20, 2006 | 03:32 PM
lancer's Avatar
lancer
Yup 18ft/lbs is all it takes!
Old Feb 20, 2006 | 03:35 PM
Joe98684's Avatar
Joe98684
so what would happen if it was torqued down tighter than this? WOuld it deform the o-rings to the point they would leak?
Old Feb 20, 2006 | 03:40 PM
PSNut's Avatar
PSNut
Very possible. U can change out the exhaust housing to a larger one to prevent
seal failure.
Nut
