This problem, that problem, and the other problem...
Old Jan 15, 2011 | 03:38 PM
Wicked Endings's Avatar
Wicked Endings
Okay! Get ready for question after question after question... But before we go into questions, let me tell you guys something I did today.
So, I was outside working on my carb, doing this and that, tightening it down to the rest of the thing. (By the way, those bolts holding down the carb were super loose! No wonder I was leaking fuel..) After that, I decided to check my valve cover and see how tight the bolts were, just for the hell of it...
All I have to say is I did a major FAIL!
After owning this truck since March, 2010, I have not once checked any of those bolts.
Every. Single. Bolt. Holding. Down. The. Cover. Wasn't. Even. Hand. Tight.
I could take the bolts out with my fingers! How was the cover even being held on there? Amazing! Must be some d@%m good sealant...
I always knew my truck had an oil leak, I could plainly see all the oil all over the motor. However, I never thought that the bolts weren't tightened down!
So, I tightened them up. However, this leads me to my first question...
How many pounds should I have them torqued down to?
They are just tiny bolts, so I don't think much more than 10 lbs or so, but... what should they be at?
The gold looking thing is the fuel filter, correct? And that vacuum port should hook up to the carbon canister next to the battery?
Is that silver canister another fuel filter? What is the other thing?
That circle at the far right, what hose hooks up to that port? The next circle to the left, what is that screw, is that the air or fuel? That bottom hose, what hose should hook up to that? The hose above that, what hose should hook up to that? That top vacuum port, what hose should hook up to that?
What is that blue cap? What's under it? Should something plug into that? What about that vacuum port plugged by a screw? What should that hook up to?
What are those two screws? Fuel? Which does which? Is one an idle screw?
What is that big nut? Could it be leaking fuel?
What is that thing sticking out? Should a hose hook to that? If so, what hose from where?
That plug in below the top hose, should a hose coming from the carb hook to that?
There are three wires coming from the alternator, and one of them is just hanging there. My truck still charges, so should that be a problem?
So, yeah, most problems have to do with the carb...
Please help me out! Thanks!
By the way, I know that I have asked some of these questions before, but I am just double checking...
Old Jan 15, 2011 | 04:26 PM
guindian28's Avatar
guindian28
I don't have any help to offer you, but I feel about the same when I climb into my engine compartment, what's that?, where's this go?, why is that hangin' there? etc... . I will say one thing, I tried tightening down one od my valve cover bolts and snapped the damn thing off, so I need to figure out how to get a bolt extractor in there to get it, it had to be the one way in the back under other stuff.
Old Jan 15, 2011 | 05:48 PM
drumfield's Avatar
drumfield
Some of the items in question stand out like sore thumbs, and I can help you with those.
I will index the answers by picture 1, picture 2, etc.
Picture 1: that is a fuel filter, and the fitting next to it is a bowl vent, that eventually connects to the vapor canister.
Picture 2: yes, that is another fuel filter(which you shouldn't need), and the other thing is your fuel pump
Picture 3: the screw is for idle mixture adjustment
Picture 5: those screws are for idle speed adjustment. The one on the solid block is for curb idle, the one on the movable "cam" is for fast idle
Picture 7: the big canister thing is your EGR valve, and there was a hose going to it
IF, and that's a BIG IF, this is the stock carb for this truck, the vacuum diagram on the radiator support would indicate where a lot of those hoses go. If not, then you would have to get that from someone who is more familiar with the motor and year of truck than I am.
Hope this helps.
Old Jan 15, 2011 | 05:50 PM
bashby's Avatar
bashby
the fuel level in the carb is below that gasket so it wont leak much
I hope your carb isnt leakig oil!!
Just snug them up good
thats the fuel filter. the nipple is just a vent, it should have a hose that goes to the charcoal canister to catch fuel vaPors but it wont effect running
thats another filter someone added, to the left is the fuel pump.
dont know, I think thats your idle mixture screw.
fast and slow idle screws
just a plug, nothing important.
EGR valve
I think so
Old Jan 15, 2011 | 05:53 PM
bashby's Avatar
bashby
I tried to make my responses a different color, sorry if it's confusing
Old Jan 15, 2011 | 06:07 PM
ctubutis's Avatar
ctubutis
Yeah, just snug up those bolts, I think the official torque specs call for 12-15 inch-pounds
this is NOT the same as foot-pounds.
IOW, not real tight. This goes for oil pan, rocker covers and carb hold-down nuts.
Old Jan 15, 2011 | 06:23 PM
smashclash's Avatar
smashclash
be careful messing with bolts, nuts, or really ANYTHING that appears wrong if it's working properly. an example of what i mean is if you had overtightened those bolts it could have been real problems.
remember, "if it ain't broke, don't fix it!"
Old Jan 15, 2011 | 09:47 PM
Wicked Endings
Okay! Thanks guys.
Hopefully, with what I did today and what i'll be doing soon, the truck should be getting better gas mileage.
Old Jan 16, 2011 | 10:48 AM
Old Hickory's Avatar
Old Hickory
If the carb has an electric choke the wire hanging loose may go to the choke.
Wicked Endings
16
Mar 11, 2014 04:55 AM
JRB65
24
Feb 5, 2013 09:05 AM
Wicked Endings
General Automotive Discussion
28
Dec 27, 2010 02:19 AM
Wicked Endings
Projects
Jul 30, 2010 11:24 PM
dixie_boysles
1983 - 2012 Ranger & B-Series
Apr 3, 2010 02:26 PM
