96 with 80-86 front cap
Old Feb 22, 2005 | 06:40 PM
jeremywright's Avatar
jeremywright
Im getting a 96 lightning and i was wondering if the front cap from an 80-86 f150 would fit. I know that most other body parts are easily interchangeable and i would really love to throw on a 86 front end. Is it possible? Easy?
Old Feb 22, 2005 | 07:43 PM
frederic's Avatar
frederic
If by front cap you mean an aftermarket above windshield (but outside) visor, the answer is yes.
The cab shells are the same from the mid 80's through 96 f-series and some 97 F350s.
Old Feb 22, 2005 | 07:45 PM
t_dickie's Avatar
t_dickie
I'm guessing you mean from clip, not cap. I'm not too sure how well they fit. I think an 87-91 would fit better, they share the same cab with the 92-96. Not sure if the 80-86 do. Personally, I'd leave it alone thoug, I like the look of the 92-96 better.
Trevor
Old Feb 22, 2005 | 08:06 PM
jeremywright
im talking about the grille, bumper, headlights, hood, fenders, etc. I havent ever seen it done, but it looks possible. I'll give it a shot because i love the 80 front end restored
Old Feb 22, 2005 | 08:15 PM
stevef100s's Avatar
stevef100s
Do what you want, but it won't fit without a bunch of work. Besides that, you would be taking a collectable truck, and making it worth a heck of a lot less. It's a bad idea, in my opinion.
Old Feb 22, 2005 | 11:13 PM
EPNCSU2006's Avatar
EPNCSU2006
It'll bolt up if you use the radiator core support from the older truck - the cabs are the same. One thing you might have to modify is the horns on the front of the chassis rails that the bumper mounts to. Are you sure you have a '96 lightning? They shouldn't exist...
Old Feb 23, 2005 | 01:34 AM
stevef100s's Avatar
stevef100s
The doors are not the same, nor is the cowl panel.
Old Feb 23, 2005 | 06:41 AM
EPNCSU2006's Avatar
EPNCSU2006
But the cab is the same, so everything in front of the cab will bolt on.
Old Feb 23, 2005 | 08:21 AM
frederic's Avatar
frederic
Even the frame horns are "close enough" if you replace the silly bumper brackets with two pieces of 1/4" thick, 8" long strips, one could drill those to mount the earlier bumper.
Like ESNC said, changing only the radiator support is required to re-nose either the later truck to earlier nose, or earlier truck to later nose.
97 and up is where the problems occur, because the cab shape is very different, and crossing parts back require a lot of hacking up. But, that too is doable. I have a 93 crewcab... and this 98 Navigator clip.... LOL.
Old Apr 13, 2005 | 11:59 PM
oldhalftons's Avatar
oldhalftons
this is good to know, I'm planning on putting a 80-86 front clip on a 87 F250
ericconn
Jan 21, 2014 07:38 AM
F-Tony
Sep 13, 2010 05:07 AM
ASNWRULZ
Aug 8, 2010 02:29 AM
moodybo
Jan 17, 2006 07:25 PM
92CajunExpress
Aug 1, 2004 07:06 PM
