Rear Wiper Stopped Working?
Old Feb 20, 2005 | 02:13 PM
wxbean's Avatar
wxbean
Question Rear Wiper Stopped Working?
Rear Wiper Stopped Working on my 98' Explorer.
I replaced the wiper motor but it still doesn't work.
Washer fluid will spray out of it but the wiper won't move.
I checked all connections around the button up front and they all look fine.
What else could be wrong?
Old Feb 20, 2005 | 02:44 PM
rollinXplorer's Avatar
rollinXplorer
you check the fuse? it should be a red 10amp....good luck
Old Feb 20, 2005 | 03:40 PM
wxbean's Avatar
wxbean
Question
I visibly checked the fuses but they seemed to be okay.
Old Feb 21, 2005 | 05:04 PM
87 XLT's Avatar
87 XLT
What does the fuse page in your owners manual tell you????
If this is wired the same as a 97 theres 2 fuses. Interior fuse panel fuse 23. Power distribution box fuse 2 which is under the hood/drivers side. Could also be a bad relay.
Old Feb 21, 2005 | 08:51 PM
wxbean's Avatar
wxbean
Lightbulb Rear Wiper UPDATE
Thanks 87XLT. I checked both the power distribution box and the interior fuse panel. Everything seemed fine. Here is what I finally ended up doing after reading numerous message boards. I realized this is one of the many "common problems" on this ford model. The rear wipers go in and out. Most likely due to the constant banging of the back door/window causing instability in the wiper motor.
So I went back to this new motor I put in and made sure all the connections were tight. I tightened bolts, wrapped tape around the connections and then lightly tapped on the motor with a hammer.
I turned the rear wiper switch "ON" and then turned the car on. Still no reaction, so I closed the back door really hard once. I started to hear somehting from the motor all of a sudden, but the wiper wasn't moving.
I turned the switch back off and wiggled the wiper manually hoping it would "catch". I tightened the rear bolt and then shut the back window swiftly.
It started working after all this FINALLY.
I came to realize though that it is very unstable with the closing/opening of the back door and I need to be very gentle with it now.
This seems to be a common problem and I'm not alone. It is a bad design and Ford knows about it.
Good luck to anyone working on there own wiper problems.
Old Feb 22, 2005 | 09:27 PM
ltfox's Avatar
ltfox
Mine is the same way on my 2000. Give the wiper a jerk once in a while and it'll start working again. What a poor design!
Old Feb 23, 2005 | 06:14 PM
wxbean's Avatar
wxbean
No kidding. It's sad to see that we all have the exact same problems.
Old Feb 27, 2005 | 10:58 AM
norrislaketn's Avatar
norrislaketn
On my 98, I found if you move the blade out of the rest position on the door it will work fine until the next time ? something happens.
makthenif
Sep 18, 2012 06:56 PM
thullz
Jun 8, 2006 10:37 AM
ron_t
Nov 2, 2004 10:29 AM
X Nuke
13
Nov 30, 2003 12:48 PM
