Problem with wiper control 98 Expedition
Old Nov 1, 2004 | 11:54 PM
ron_t's Avatar
ron_t
HELP! Having a little issue with the wiper control. Works fine some of the time - but occasionally, it seems that it gets confused as to what it should be doing i.e. - when I turn to intermittent, it won't work at all - if I crank it up all the way to high - the wipers will come on intermittently. Sometimes, the wipers will stop - when this happens, I turn them to OFF then back to high and they usually will start operating again. Also - seems that when I use the turn signal - it will cause the wipers to start working as well.
Old Nov 2, 2004 | 10:29 AM
buzzard's Avatar
buzzard
The multifunction switch that controls those functions is known to have problems. You might call a Ford service dept. and ask about replacement under a recall.
phoneman91
64
Feb 2, 2025 05:40 PM
gmhorse
6.7L Power Stroke Diesel
163
Jul 6, 2020 09:16 AM
mytimeistoday
Jan 26, 2015 06:38 AM
Jesser02EX
Mar 4, 2014 06:31 PM
1fordsoldier
May 14, 2006 11:17 AM
