Lockers
Old Feb 16, 2005 | 07:58 PM
XuPiTeR's Avatar
XuPiTeR
Lockers
What kind of lockers would be ideal for an F-150
Old Feb 16, 2005 | 08:52 PM
tex94F250's Avatar
tex94F250
F150 with what engine, gear set, wheelbase, lift, tires? It also depends on what you want to do with the truck. For most general 4wd use on a daily basis my factory limited slip is more than enough.
Old Feb 16, 2005 | 08:54 PM
Thomasm67's Avatar
Thomasm67
Question #1 what are you gonna use your truck for? Question #2 what size tires are you gonna run on it? As for locker's if your just gonna run 33's then locktite or powertrax will work for you if you are going to a 35 or bigger then you'll need to get a suspension lift kit and go with different locker's like ARB,Detroits,Auburn, and so forth name brand's. If your just gonna run it as a daily driver then limit slip will work for you if you don't already have that in your truck.
Old Feb 16, 2005 | 10:05 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Here are some traction diff manufacturer websites if you want to read about their different products:
www.tractech.com (Detroit Locker full-case auto-locker, True Trac worm-gear limited slip, Electrac electrically selectable locker/ltd-slip, EZ Locker auto-locker that goes in the stock case).
www.powertrax.com (Lock Right and NoSlip auto-lockers that go in the stock case).
www.auburngear.com (2 models of cone-clutch limited slips, ECTED electrically selectable locker/ltd-slip).
www.traction.eaton.com (Eaton Posi clutch-type limited slip, E-Locker electrically selectable locker).
www.precisiongear.com (Dana-designed Trac Lok and Power Lok clutch-type limited slips for Dana axles).
www.torsen.com (worm-gear limited slip).
www.arb.com (Air Locker, pnuematic operated open diff/spool).
Depending on the year of your F150, your axles are most likely Dana 44 TTB front, Ford 8.8" rear.
spquint
1983 - 2012 Ranger & B-Series
Mar 5, 2007 09:28 AM
176ford
Offroad & 4x4
19
Apr 12, 2004 09:14 PM
bronco cam
1978 - 1996 Big Bronco
Nov 29, 2002 01:43 AM
Nathan
Offroad & 4x4
13
Dec 24, 2000 05:18 PM
Eddie
Offroad & 4x4
Dec 10, 2000 04:07 AM
