timing
Are you in Australia? They did not put Cleveland engines in anything in the US after about 73 or so.
Regardless of which engine it is, if the mechanical and vacuum advance systems in the distributor are working correctly, just keep advancing until it pings and then back it off a little at a time until it no longer pings. You should use a timing light to check avance mechanisms and then use the timing light to make note of setting after you have done the trial and error setting.
Good luck,
Doc
Good luck,
Doc
Originally Posted by Nohaj1
Could anyone tell me what the specs are for timing a 78' 351 Cleveland Im not sure how many degrees above top dead center I should go.
thanks
thanks
Varnish
06-25-2002 02:52 PM
