transfer case fluids
Old Feb 14, 2005 | 07:14 AM
android7105's Avatar
android7105
how do I check the fluid levels on the transfer case? also what type of flush or main... is good for it. Where does the fluid go in? Its a 79' f150 351m all factory. Sorry for all the questions at once, and thank you for your anticipated answers. Andy
Old Feb 14, 2005 | 06:00 PM
mark a.'s Avatar
mark a.
There are two square plugs on the back of it. Bottom one is the drain. Fill the top one till it runs out.
Old Feb 14, 2005 | 08:11 PM
midlf's Avatar
midlf
Flush with the same fluid you fill with, ATF. It's cheap and doesn't take much. Flush till clean fluid comes out. DO NOT overtighten plugs when putting them back in.
Old Feb 15, 2005 | 07:39 PM
android7105
thanks
thanks guys the fluid now is black will do w/ atf
Old Feb 15, 2005 | 09:36 PM
78fordman's Avatar
78fordman
I do beleive the NP205 takes 80-90, not ATF.
Old Feb 16, 2005 | 08:51 PM
SoCalDesertRider's Avatar
SoCalDesertRider
78fordman is right, no ATF in the NP205. Use gear oil.
Old Feb 17, 2005 | 07:19 AM
skuteman's Avatar
skuteman
...............The old Ford 1977 Service truck (green) Manual recommends 50 wt. engine oil. i.e. 4.5 PINTS...sk
Old Jul 27, 2005 | 11:19 AM
rowdy123's Avatar
rowdy123
I have a friend who has a 79 Ford just like mine. I run 85W90. He runs A.T.F.
Neither one of us has ever had a problem yet. Odd how they will run with either one and no problems.
texrdnec
May 10, 2017 06:40 PM
willpjones
Aug 19, 2016 02:41 PM
timbersteel
Aug 26, 2013 12:56 PM
kcode
Dec 30, 2011 08:19 PM
phillyfreak
Aug 12, 2011 11:19 PM
