Hey All!,
I have a 77 f-150 that i dropped a 351C into. Its a 2wd with a 3 speed auto, so it drives like a car. I built up my Cleveland in June, and it runs awesome. But I do have a problem. It only has a 2bbl on it and I want to slap a 4bbl on 'er. I dont know much about matching a 4bbl intake to the 2bbl/2 valve heads.
new here ,but i would recommend that you go ahead and get a 4bbl intake ,if you built up the motor ,you don't want to "choke" the 4bbl,,they do sell adapter plates to mount 4bbl to 2 bbl intake
Yep, the 4V heads have much larger ports. They are really for high rpm use. The 2V heads have good sized ports and valves and the Edelbrock Performer for 2v heads works great. I had one on a 71 351C that I had years ago.
you can buy a nice set up for under 300 or cheaper used but i would buy the carb new the intake you can find used i just sold a edelbrock 351 c on ebay for 65.00
