1978 - 1996 Big Bronco
351W 2bbl to 4bbl
Old Jul 23, 2003 | 02:27 PM
rticwrrior2000's Avatar
rticwrrior2000
351W 2bbl to 4bbl
Ok,
I just purchased a stock 4bbl intake manifold from a parts yard. I wanna swap me 2bbl intake for the 4bbl i just purchased. Problem is, there are some extra holes for the coolant passages on the 4bbl that just dont match up on the 2bbl. Anybody have maybe a website that would tell me how to do it.
Ive got a 83 Bronco 351W and i wanna put a holley 650 on it.
Old Jul 23, 2003 | 03:11 PM
Big Red Bronco's Avatar
Big Red Bronco
351W 2bbl to 4bbl
Hi, interesting question. Is the HOlley for a Ford 351W? Are you sure about the intake?
Did you go to Holley website? http://www.holley.com/
And send them the same question?
Don't like answering a queston with questions. But, you need to find a lot of answers, and the tech support at Holley is a great way to start.
Bruce (Big Red Bronco, getting ready to have it's engine pulled)
Old Jul 23, 2003 | 03:28 PM
mrwizard's Avatar
mrwizard
351W 2bbl to 4bbl
I don't think the problem was the carb, I think the problem was the intake manifold.
What year engine did the 4bbl manifold come off of?
Old Jul 23, 2003 | 11:13 PM
Chris_ce's Avatar
Chris_ce
351W 2bbl to 4bbl
The 4brl intake is from a 351w ho.they came with 4v heads instead of 2v heads so I think you are going to have to get the heads also.You could always go with a aftermarket intake.
Old Jul 31, 2003 | 12:09 AM
GypsyR's Avatar
GypsyR
351W 2bbl to 4bbl
If you are talking about the two rearmost passages on the intake itself, don't worry about it. They came either open or closed from Ford and the aftermarket stuff. Most folks seem to believe having the crossover is better and a few have even drilled out the blocked ones and installed a crossover hose.
I've yet to see evidence that either version makes any difference in water circulation. If you're saying your "new" manifold has the crossover open, just make sure your new gaskets are also "open". I'm almost certain they will be, but check to be sure.
Old Jul 31, 2003 | 04:13 PM
rticwrrior2000
351W 2bbl to 4bbl
thanks for the info guys, got it all figured out.
mac1405
Apr 4, 2015 04:50 PM
Salomon Trujillo
May 5, 2013 03:20 PM
86ford302help
27
Apr 4, 2013 10:19 PM
Brooksd1991
Oct 22, 2009 11:27 PM
icuhatn99
Feb 5, 2006 10:35 PM
