bad brakes
Old Feb 14, 2005 | 08:49 AM
pnose's Avatar
pnose
Check the rear flex hose,they can sometimes act as a check valve when they collapse internally.
Old Feb 14, 2005 | 11:45 PM
asluff's Avatar
asluff
Just replaced master to fix simular problem only to find breaks still not up to snuff. Further investigation found emergency brake cable on the drivers side was bad replaced this and for me "case closed".
Old Feb 15, 2005 | 12:39 AM
PLC7.3's Avatar
PLC7.3
Quite often when backing down a long hill we tap the pedal several times. Problem is the vacuum pump/system will be drained if the truck is at low idle in about 4-5 pumps of the pedal and then no power assist is available.
One other point is the quality of the brake pads and shoes has a lot to do with stopping power. You get what you pay for in the long run. Skimming/turning the rotors and drums is required anytime new brake pads or shoes are installed if you want proper seating. Always have the thickness of rotors and inside dimentions of drums checked before skimming and installing new brake pads and shoes. Oversized drums and thin rotors will warp very quickly and can cause poor or severely reduced braking at best.
Old Feb 21, 2005 | 02:40 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Finally got a brake booster/master cyl. that was properly rebuilt. now we really have good breaks. Thanks to all for the info it really helped. especially the failure rate of rebuilds.
Pincheweddo
13
Apr 4, 2014 11:41 AM
ADTMan
Jun 7, 2011 01:05 AM
2010Raptor
Large Truck
Aug 26, 2010 08:47 AM
harleymsn
Jul 15, 2010 10:20 PM
booputt44
Feb 15, 2005 02:56 PM
