TPS adjustment/remove
thanks guys
P.S
92 F-250 7.3 4x4 automatic E40D (i beleive)
Hook up the negative lead of the volt meter to the battery ground and the positive lead to the center GY/W ( grey/white wire which is the FIPL signal wire, I use a paper clip up the side of the wire in the connector. The FIPL must be attached to the wiring harness. Engine low idle speed must be set to specs prior to adjusting the FIPL. Engine off key on........
With a warm engine, key on, engine off measure the voltage at the GY/W wire, if adjustment is required loosen either the bracket with bolts or just use the slack in the Torx screw holes. Now gently rotate the FIPL until you get some where between 1.05V and 1.1V. then tighten the torx screws or bolts which ever you loosened ensuring no movement of volt setting . Rotate the throttle lever to WOT see if you get 3.8 V but not more than 4.3 V.
The FIPL mounting bracket can be moved but ensure it is centered for a good rotation. Any adjustment should be made by only rotating the FIPL. If a new FIPL is required, check tang engagement as you take off the old FIPL and then make sure that the tangs in the new FIPL engage the throttle lever properly.
The closed throttle voltage: 1.1 V, .........wide open throttle voltage: minimum of 3.8 V but
could that be off enough to trip trouble code? or is the TPS bad? i have not tried adjustment yet i wanted to get back with yall on voltages
Yep, that's enough to send a code. TPS/FIPL may be bad, there's another voltage test you can do, but I can't remember the the specs or which wire it was. I would just go adhead an adjust the TPS till you get it within specs and see if the code goes away. It won't take much movement to get your where it should be. Be sure to check for throttle binding after you adjust the TPS and disconnect the fast idle soleniod before voltage tests.
thankx for all the help
