Weak starter?
Old Feb 9, 2005 | 03:29 PM
FLgargoyle's Avatar
FLgargoyle
Weak starter?
My '86 2.3 Ranger turns over very slowly sometimes- but only the first compression stroke, as if it's hard to turn and then suddenly frees up. I don't think it's too much compression w/ 185K miles on it! It doesn't do it all the time, and usually not when the engine is warmed up. I'm in FL, so we don't get real cold nights. Do you think the starter may have a dead spot in it?
Old Feb 9, 2005 | 08:39 PM
Ken00's Avatar
Ken00
Do you get any black smoke when it starts? How's the battery/cables?
Old Feb 10, 2005 | 03:02 PM
FLgargoyle's Avatar
FLgargoyle
No- I get a lot of blue smoke; valve seals are gone. I'll check the battery connections this weekend- haven't done that in a while.
Old Feb 10, 2005 | 05:35 PM
Dan Robertson's Avatar
Dan Robertson
You are describing a dragging starter. I would begin by checking all of the connections, making sure they are clean and tight. Then I would have a load test put on the battery. If all of that checks out OK, then I would consider the starter itself. An easy check would be to turn on your headlights and have a helper watch them while you start the truck. The lights should not dim very much or for very long. If they do, I would suspect the starter (bad armature). If the armature is bad enough, the lights can almost go out. With 185000 miles on an 86 four cylinder, I dont think that compression would be much of a factor. Good luck.
Old Feb 10, 2005 | 06:40 PM
el conquistador's Avatar
el conquistador
why not pull the starter and have it tested at autozone or the like?
Old Feb 11, 2005 | 05:45 AM
Dan Robertson
Because the "head light test" doesnt cost anything.
Old Feb 11, 2005 | 01:44 PM
el conquistador
getting them tested at autozone is free also.
Old Feb 11, 2005 | 03:01 PM
FLgargoyle's Avatar
FLgargoyle
Having a starter checked is free, if you don't count having to pull it out and drive down there. I'll check the connections this weekend; maybe have the battery checked, and do the headlight test. Then maybe I'll pull the starter. Thanx for the input.
Old Apr 16, 2005 | 03:22 PM
FLgargoyle's Avatar
FLgargoyle
I finally replaced the starter- it was still working, but getting worse and worse. I also replaced the battery cables, and the cable from the solenoid to the starter. That cable in particular was very bad. Works like a champ now!
Old Apr 16, 2005 | 06:31 PM
Ken00's Avatar
Ken00
Glad to hear it doing good now!!
Old Apr 17, 2005 | 08:06 PM
Bart99GT's Avatar
Bart99GT
As I'm sure you discovered, pulling the starter on the 2.3L isn't that difficult. I can do it in less than 15 minutes if I'm in a hurry. Fortunately there's not much in the way down there.
jhand124
Dec 5, 2013 06:30 PM
JoeKramer
16
May 7, 2011 03:10 PM
jdhudall
Apr 22, 2009 12:48 AM
mongo75
May 6, 2008 08:28 PM
airharley
Aug 19, 2003 09:42 AM
