compression check on a 351W??
Old Apr 21, 2009 | 10:34 PM
jdhudall's Avatar
jdhudall
Question compression check on a 351W??
I bought a 351W from a salvage yard is there a way to test the compression with out a starter or engine cradle?? I tried to turn it over by hand but only got 40psi for compression on my tester but I don't think that is right because I can't turn it over that fast! I just want to see if it will need a rebuild or not please help!! They claim it was a running engine when it was pulled I hope it will work for me I don't have much money for a rebuild!
Old Apr 21, 2009 | 10:49 PM
flamebuster's Avatar
flamebuster
It can be done, and it will take 4-6 revolutions to build up to an accurate reading.turning by hand is really slow. are you using the starter.?
Old Apr 21, 2009 | 11:15 PM
jdhudall's Avatar
jdhudall
no I don't have a starter for it yet is turning it over by hand fast enough to get a accurate reading I turned it over a couple times but not 6 revs I will try turning it over a couple more and see! I just think the slow turning might loose some of the compression while on the compression stroke? but I am no expert that is why I am asking
Old Apr 21, 2009 | 11:57 PM
greg176's Avatar
greg176
The only way to do a compression test properly is with the starter.That said you could try doing a leak down test.Google it.That is how small aircraft engines are checked.
Old Apr 22, 2009 | 12:48 AM
jdhudall's Avatar
jdhudall
Thanks now I am not so worried about having to rebuild it right away!
87crownvic2door
16
Dec 24, 2014 05:51 PM
hondod
Oct 1, 2012 09:57 AM
FLgargoyle
1983 - 2012 Ranger & B-Series
Apr 17, 2005 08:06 PM
Redj
Oct 8, 2004 06:30 PM
catdiesel
Aug 18, 2004 09:31 PM
