Pyrometer install ??????????
Old Feb 9, 2005 | 02:43 AM
mauisuperduty's Avatar
mauisuperduty
Hi,
From what I've been reading, most of you agree pre turbo installation of pyro is best if I'm not mistaken. What install method is best/how did you install yours? Thank you very much.
MauiSD
Old Feb 9, 2005 | 06:44 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Do a search here in the 6.0 area ...some great reading.
When you find it, link the thread here, and Daryl or I will place it in the Tech Folder....
Old Feb 9, 2005 | 07:52 AM
Maxium4x4's Avatar
Maxium4x4
Nice web page of the install but it is at Diesel Manor....wunder if FTE will redirect...
https://www.dieselmanor.com/diy/PSD3-gauge/image24.htm
Well just cut and paste in another browser...Yup...redirected...It is just a picture and directions.....make sure you buy from MotorHaven because they provide us with this nice web site...
Old Feb 9, 2005 | 09:16 AM
LasVegas F250's Avatar
LasVegas F250
I would also recommend sacrifice a telescope magnet. Put a 90 degree bend in it and retrieve the rest of the metel shaving. After vaccuming the hole out, if your not going to remove the manifold.
Old Feb 9, 2005 | 02:08 PM
sv250's Avatar
sv250
Pulling the manifold isnt that bad. I tried it with out pullig and went crooked with the tap. I had to pull the manifold retap my first hole and plug it and do anothe hole on the flat part of the manifold. Very easy to do in a vice. Many others have done it on the truck with no problems, I wasnt that lucky.
Old Feb 9, 2005 | 02:16 PM
nosdog2's Avatar
nosdog2
I did it very slowly with a combo of a shop vac and brake grease(when taping). It was very easy to get to on the pax side manifold, you don't even have to jack the truck up.
Old Feb 9, 2005 | 03:08 PM
Daryl Hunter's Avatar
Daryl Hunter
I removed my exhaust manifold to do the drill and tap off the truck. Wasn't that hard but if I were to do another one I'd probably do it on the truck.
Another thing that some folks have done is to do the drill and tap with the truck running. This way there's a positive pressure on the inside of the manifold that is supposed to blow any chips back out as you're drilling/tapping.
Just a thought . . .
Old Feb 9, 2005 | 05:54 PM
trencherman's Avatar
trencherman
Drilled manifold on truck(very easy to drill) oil on bit, shop vacumed, used telescope magnet and welded bushing on manifold. good luck
7.3 down
Aug 19, 2015 10:43 AM
Alex Ulmer
Sep 2, 2013 12:20 PM
John Diem
May 30, 2012 01:55 PM
jboard
May 26, 2010 08:48 PM
halfdozen
Dec 29, 2004 10:56 PM
