Wicked Wheel Install
Old May 24, 2010 | 09:50 PM
jboard's Avatar
jboard
Question Wicked Wheel Install
I just ordered the wicked wheel and I was wondering whats the best way to install it?
-------------Jeremy
Old May 24, 2010 | 09:51 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Remove the turbo and install on the bench.
Old May 24, 2010 | 09:55 PM
jboard's Avatar
jboard
10-4 thanks
Old May 24, 2010 | 10:03 PM
worm5932's Avatar
worm5932
i did mine in the truck and would take it out next time, also i would have adjusted the wastegate rod. use a HALF INCH impact, my cousin handed be the 3/8 and told me it was the 1/2 and after 20 minutes or so of thinking it wouldnt come off i checked, then it came right off. if you plan on doing it in the truck you will need alot of extensions, universal joints, and wrenches.
Old May 24, 2010 | 10:10 PM
jboard's Avatar
jboard
Ive taken the turbo off my old 97 and it was a real pain getting the pedestal bolts out and in...I haven looked at this truck too much yet but can the turbo be easily unbolted from the pedestal and leave the pedestal in the truck?
Old May 24, 2010 | 10:27 PM
Riffraff Diesel
PREMIUM SPONSOR
Yes, the hardest part will probably be taking the v-clamps off the downpipe and up-pipes. Don't forget new o-rings.
Old May 24, 2010 | 11:15 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
By using a small diameter screwdriver I managed to dent my impeller, even with the benefit of Most Holy Duct Tape wrapped around it. The slim shaft went around the turbine blade. On the bench with a beefy, taped screwdriver is how I'd do it next time. Many good install threads, check 'em out.
Old May 24, 2010 | 11:33 PM
big poppa's Avatar
big poppa
I did my WW switchout while the turbo was on the truck, with the padded screwdriver trick, It worked but it was a very risky procedure, possible bent exhaust fins are possible. A member here bent his and I ended up lending him my stock turbo to get him on the road again, fast. I vote removal of the turbo for this very reason.
Old May 25, 2010 | 12:45 AM
Visseroth's Avatar
Visseroth
Agreed. I got lucky on mine when i replaced my WW due to stock air box wear and tear. I stuck a screw driver in the turbine and used a ratchet and really had to reef on the thing though I was scared of bending the fines and was trying to be as careful as possible I managed to get the impeller off without bending anything. I've heard impact guns are wonderful for this job. Best thing to do is try and hold the impeller as close to the center as possible.
I got lucky I think, I checked the turbine, didn't see any bent fins, everything looked good and thus far haven't seen any problems but definitely nerve racking.
Old May 25, 2010 | 12:46 AM
Visseroth's Avatar
Visseroth
Definitely a PITA!!!! Those stupid clamps! Hate them!
Old May 26, 2010 | 08:48 PM
worm5932's Avatar
worm5932
i used a half inch impact with a 5/8 socket and hit it from a stop and it came off without holding the exhaust side.
green_95
Jan 15, 2016 07:32 AM
v10tritanium
Oct 18, 2015 03:43 AM
mrwrench
Sep 3, 2015 02:21 PM
avi
Jul 18, 2007 04:34 PM
01f350
19
Mar 19, 2006 04:21 PM
