Backfire
Old Mar 24, 2002 | 10:29 PM
Martin85xl's Avatar
Martin85xl
Backfire
I could use some help. I have an 85 F250 with a 351w, 4brl.carb auto trans, about 70000 mi. I get some pretty severe backfiring, mostly in the morning when it's cold. I'm afraid my neighbors are circulating a petition.
Old Mar 25, 2002 | 09:13 AM
tomw's Avatar
tomw
Post Backfire
If it is backfiring thru the carb, probably choke is too lean.
If it is backfiring out the exhaust, probably have something wrong
with the AIR pump or control valves. Check for loose, broken, or
cracked vacuum lines under the hood. Some engines have a 'gulp'
valve that stops air pump air flow when you slow down so that the richer mixture on cold start cannot explode in the muffler/exhaust.
UNEEDA book to know what your system has...
I'd also check the plug wires for a possible cross-fire. Plug wires
should cross at a sharp angle to prevent firing a plug inappropriately.
Once the compose reply window opens, the original ? is not visible,
so I can't remember the engine/year, etc.
Some places to look...
tom
Old Mar 25, 2002 | 10:17 AM
Mil1ion's Avatar
Mil1ion
Backfire
Engine timing
Cracked Distributor cap,carbon tracking, or condensation in it
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
[i][font color=red]Calgary,Alberta,Canada[/font][i]
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=3140&.jpg
http://community.webshots.com/user/mil1ion
[font color=green] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
Old Mar 25, 2002 | 09:26 PM
rocky2's Avatar
rocky2
Backfire
Backfire though carb=dist.cap/wires/
Backfire in exshaust=pollution air pump diverter valve.Take off belt and check
Old Mar 26, 2002 | 08:46 PM
Martin85xl's Avatar
Martin85xl
Backfire
Thanks for the help. The backfire is through the exhaust. It runs real well once its warm and even when its cold except for deceleration and sometimes starting, if it does'nt start on the first crank. Someone mentioned a dashpot on the carb that may be bad or need set.
Old Mar 26, 2002 | 08:51 PM
Martin85xl's Avatar
Martin85xl
Backfire
I've been chasing a squeeling belt. Could this be the air pump? Can I get rid of the pump? I would like to install headers in the future and that would simplify things alot. Again thanks for the help
Old Mar 27, 2002 | 12:41 AM
skyranger_ca's Avatar
skyranger_ca
Post Backfire
I have the same truck with dual air pumps.Had same problem,Have two air diverter valves on the truck, one feeding both exhaust manifolds and the other feeding to the rear pipe connecting the heads.The front valve was was not working.I took the rear valve and swapped it for the front one and put the faulty front one on the rear. it cured the problem. I ran like this for a year and finally got rid of the air pumps. hope this helps
Old Mar 27, 2002 | 07:33 PM
Franklin2's Avatar
Franklin2
Backfire
joshyg78
1978 - 1996 Big Bronco
May 30, 2010 01:19 AM
reflections
Sep 15, 2009 07:42 AM
coleaclark
37
Apr 11, 2008 02:07 AM
jimmybruce
Mar 21, 2005 12:13 PM
Fordiod
Apr 21, 2002 06:02 PM
