its backfireing through the intake i belive also the disributor cap it kinda wabbally also its dead on for the timing and has had a tune up somone told me it could be fuel pump or fuel regulator or the distiboter cap
i dont know much about it i just bought it it does miss on idle its just backfires when i presshard on the gas when i play with ditributor it get s better some times
to start with... while it's idleing pull one plug wire at a time out of the cap and replace it. when you pull the wire it should be noticable that you did, (the motor should start skipping and shaking)... when you get to the one that dosen't seem to change how it's idleing thats the one that is skipping and giving you problems.
report back... and don't worry as long as you pull them out at the cap you wont get zapped...
could be a simple as a bad plug or wire...
just need more info
Mileage?
tune?
might be water in the fuel
how is the vacuum hooked to the distr.? manifold or ported vacuum?
could be a plug wire crossed... check the firing order.
well the firering order is right the guy i bought it from said the fuel pump did have problems and he said that the fuel filter hasent been changes for a while
