1978 - 1996 Big Bronco
big backfire!!!! help!!!!
Old May 28, 2010 | 07:41 PM
joshyg78's Avatar
joshyg78
so i have a 78 4x4 ranger xlt w 400. lots of new parts... was running wonderful until i left work today. ran for a sec then quit. when i went to restart, there was a backfire that rivals my 357! scared the crap out of me. it wont start. turns over and eventually backfires (loud) again. my wifes 8.5 months preggo and i need to get this mother back on the streets! thanks for your time
Old May 28, 2010 | 08:25 PM
g_k50's Avatar
g_k50
Timing chain broke or skipped a tooth. Were you practicing your drag strip starts?
Old May 28, 2010 | 08:26 PM
g_k50's Avatar
g_k50
Thanks for coming to the Bronco Forum for your answers.
Or should I say questions about a ranger xlt?
Old May 28, 2010 | 08:33 PM
joshyg78's Avatar
joshyg78
its a bronco ranger xlt... sorry. i thought it was the timing chain but didnt know for sure. does this mean i need to replace the chain? i was gonna go gear drive. is it possible i messed other things up? thats the last thing that needs to be replaced. everything else is new.... this is a big bummer.
thanks for the input i really appreciate it.
Old May 28, 2010 | 08:36 PM
g_k50's Avatar
g_k50
What's a 357? Is that a gun or a Cubic Inch Displacement?
If it's a gun sell it and get the "Bronco" fixed.
Old May 30, 2010 | 12:54 AM
kenjh's Avatar
kenjh
pull the number one plug out unplug the coil so there is no spark and bump the motor over till you get it on compression on #1 then pull the distributer cap off it should line up with #1 if it dosn't then there is a problem ..if it lines up it may be a carbon track causing the missfire..let us know what you find out..
Old May 30, 2010 | 01:19 AM
greystreak92's Avatar
greystreak92
OK, I see the smart-*** fairy has visited the forum again. (If you don't recognize the trim package designations on a particular year Bronco, don't belittle someone who does or worse HAS one you don't know about... Ford didn't even MAKE the Ranger model in 78 so it wouldn't be anything BUT a trim level).
On to the issue at hand... Ditto to what kenjh has already said. Some of us are more interested in helping than cracking wise at the expense of new-comers.
Hmann
Mar 6, 2010 08:22 AM
Ford F1Fool
May 12, 2008 06:29 AM
coleaclark
37
Apr 11, 2008 02:07 AM
gearhed1971
Apr 8, 2007 08:10 AM
Fordman350
Dec 12, 2002 11:19 PM
