Modular V10 (6.8l)
Ford service driveability test?
Old Feb 7, 2005 | 10:15 AM
kenneBF250V10's Avatar
kenneBF250V10
Has anyone ever had a driveability test done on their Super Duty. The reason I ask is because I think I might have a slight misfire and am wondering if this test will detect it and let me know which cylinder is the problem. Is a misfire usually caused by a faulty coil?
Old Feb 7, 2005 | 10:30 AM
Big Orn's Avatar
Big Orn
Yes, I have. With a good tech, it can detect anything.
Yes, usually.
Old Feb 7, 2005 | 10:43 AM
kenneBF250V10
Thanks, I'm going to go ahead and have it done, can't hurt, I don't believe it costs very much.
Old Feb 7, 2005 | 11:12 AM
Big Orn's Avatar
Big Orn
The tests were from $36 to $45 for me. Others on here have complained about the $75 min charge. I guess it depends on where you go or what PR you have with the dealer - or both.
Old Feb 7, 2005 | 01:13 PM
SMiller's Avatar
SMiller
Mine has been acting kinda funny for a while, sometimes it runs great and pulls strong and other times it misses out when I try to get on it, never know when it will do it, hasn't done it in a couple days, thought I got water in a coil and it dryed out, then it was back a couple days later and then gone again. Ran a test on the truck and nothing came back, I don't know what to do....
Old Feb 7, 2005 | 02:04 PM
Big Orn's Avatar
Big Orn
Did they (dealer) put it on the WDS and do the drivability test? If so, you might want to go to another dealer or at least get another tech. The system needs a little info from a good tech in order for some things to show up.
Old Mar 31, 2005 | 01:13 AM
99F350Driver's Avatar
99F350Driver
If the tech runs a power balance test with the WDS he will most likely see the cylinder that is misfiring. It is pretty evident if you monitor that with the engine under load. There may or may not be misfire codes. I've seen it both ways but the power balance test always shows the misfire. Monitoring the engine under load is the key.
Take care,
Rich
Old Mar 31, 2005 | 02:49 PM
captchas's Avatar
captchas
Guest
Thumbs down we have v10's not 8's
a 5.4 is not a v10 . related but not the same try and ask the 5.4 guys
Old Mar 31, 2005 | 11:19 PM
99F350Driver
Who said anything about a 5.4??
Total Gearhead
17
Dec 24, 2013 10:58 AM
luthoro
Sep 1, 2012 06:42 PM
66LJ
Jun 26, 2008 07:29 AM
fordxxx
16
May 23, 2006 03:43 PM
DMHG
Modular V8 (4.6L, 5.4L)
Nov 7, 2004 11:44 AM
