Driveability with Trac-Lok
Old May 15, 2006 | 01:38 PM
fordxxx's Avatar
fordxxx
I just bought a 3.70 centre section for my '72. It has Trac-Lok...is there any negative driveability issues with Trac-Loc? How does it work?
thanks
Old May 15, 2006 | 05:34 PM
averagef250's Avatar
averagef250
Assuming it's a 9 inch? 9" trac-locks work pretty good. Dana 60 trac-locks are a down grade from an open diff.
Old May 15, 2006 | 08:26 PM
7DF250's Avatar
7DF250
I doubt there is any differance between a 9" trac lock and one in a Dana 60. It is all in the clutches I think in the tech article sect. there is a write up on how to rebuild a trac-lock, maybe it was in one of the off road mags. Trac lock is Fords name for a limited slip, just like GM calls theres posi traction. Drawbacks on the street,virtually none if its wore out, in good shape or "tight" barely noticable. Off road it is better than an open diff but wont get you much further. Remember to add the little bottle of special oil for the clutches for it to work properly,can't remember what it's called right now but someone here will.
Old May 15, 2006 | 08:52 PM
averagef250
It's called friction modifier. All quality gear oils come with it nowadays. You can add more if the clutches chatter.
Old May 15, 2006 | 10:50 PM
Ford_Six's Avatar
Ford_Six
Trac-Lok is ok, but the clutches wear out fast. After that, you just have an open diff. I had a factory detroit locker in my 72, worked pretty seamlessly, hardly even noticable.
Old May 15, 2006 | 11:18 PM
WillyB's Avatar
WillyB
The only issue is that on real slick roads it can make the truck hard to turn - a slight understeer on ice or mud. I have always found that the improvement in off-road traction well worth whatever slight problem it causes in steering.
I did buy a new truck one time with the trac-loc on both the front and rear axles. Mostly I think it would have climbed a tree, but uphill on a muddy clay road it was almost uncontrollable. I will never again have it on the front axle.
Old May 16, 2006 | 08:51 AM
woods's Avatar
woods
A Trac-Loc diff is probably the lightest duty limited slip to use in your truck.
It will help over having an open diff but not by much.
Like WillyB said, you may have issues in slick or Icy conditions.
Other than those 2 conditions you may not even notice it is back there until you need it.
I had installed one many years ago in the front of a full time Power Wagon and it was interesting to drive. Got use to it and drove it like that for a couple years.
Ended up upgrading axles to part time and installed a rear Detroit Locker.
I would use it if it was me or upgrade to a Power-Loc or better for the rear.
Good luck.
Ken
Old May 16, 2006 | 11:33 AM
fordxxx's Avatar
fordxxx
I bought the centre section for the 3.70 gears so any benefit from the trac-lok will just be a bonus. Might come in handy if I start driving the truck as my daily driver in the winter.
Old May 16, 2006 | 01:27 PM
Pkupman82's Avatar
Pkupman82
I have heard Trac Loks don't hold up well in a rear axle. I am running one in the front of my 84 F150 and a Power Trax No-Slip in the rear with 4.10s and 33 inch mudders. That truck is really hard to get stuck, and will climb up and over almost anything! The downside is it doesn't steer worth a crap on slick of loose surfaces, I wouldn't dare trying to run it on a hard surface! IMO I think they work best in front axle applications on vehicles that are used for moderate to somewhat difficult off roading. When it comes to a dedicated 4 wheeler there is no substitute for spools and lockers (or welding for you rednecks out there )
Old May 21, 2006 | 02:13 PM
1972ford_f-100's Avatar
1972ford_f-100
so like i bought a truck and it had trac locs in both front and rear,i am wondering would this truck be a good app. for a snow plow or no? cause it sounds like one ya'll say yes in winter others say no,lol
Old May 21, 2006 | 04:23 PM
woods's Avatar
woods
Looks like you are in Minnesota.
No chains or studded tires are allowed, correct?
Not sure if the trac-locs would be help or hinder you while using the plow.
good snow tires and working with the air pressure in them to get the optimum traction would be your best bet.
I would try one season with the trac-locs and see how they work.
Be careful and good luck.
Ken
Old May 21, 2006 | 11:05 PM
1972ford_f-100
ok,y minnesotaq kinda sux but ya,thx
Old May 22, 2006 | 06:30 AM
Dave Severson's Avatar
Dave Severson
It will do some funny things to your steering, but front and rear traction lok differentials will definitely move some snow!!! The clutches will wear out, but certainly no big deal to replace them.
Old May 22, 2006 | 07:14 AM
WillyB's Avatar
WillyB
As you already have it, I would install it and see how it worked. If it gives you problems with steering on slick roads you can change back to the original open front end.
Old May 22, 2006 | 12:28 PM
7DF250's Avatar
7DF250
I think that with a plow & a tracloc up front I would avoid heavy throttle with the wheels turned it will probably burn up the clutch pack pretty fast, but then again what do I know about plowing I live in southern CA.
