Airbag light is blinking
Old Feb 7, 2005 | 01:24 AM
ptt's Avatar
ptt
1995 E150 w/E4OD conversion van. It has 175K or so miles showing. Is this light programmed to start blinking at a predesignated milage point? Thanks.
Old Feb 8, 2005 | 04:02 PM
bluedund's Avatar
bluedund
Same happend to me, and from this forum, learned that the 3-2 (or 2-3) blink means that your clock-spring mechanism inside the stering column is busted. Don't know what that means, other than the airbag won't work, but here in Texas apparently you don't need an airbag for an inspection certificate. I just watch mine blink.
Old Feb 9, 2005 | 09:40 AM
ptt's Avatar
ptt
Airbag light......
Is it true that the light is programed to start blinking so the dealership can get you in to service your wallet? A friend said to just put a strip of black tape over it.
Old Feb 9, 2005 | 06:03 PM
SuperCrewDude's Avatar
SuperCrewDude
My '94 F-150 blinked a 32 for a long time. The horn also would not work. It's not pre-programmed. Something broke. The clock spring is a very likely culprit. I just never had my truck looked at to find out for sure.
Old Feb 10, 2005 | 08:13 AM
Crash687's Avatar
Crash687
clock-spring mechanism inside the stering column is what wiring from the air bag, horn, etc. to be able stay connected while you turn your steering wheel.(simple wording explination)
Old Apr 10, 2005 | 11:48 AM
capstan's Avatar
capstan
On my 95 E-150, I had to fix the parking brake cable. While reinstalling the foot pedal assembly, the sharp edge of it nicked a wire in the bundle coming from the steering column, causing a few sparks. Now I get the blinking seat belt lite. I just put black tape over it, and hope I never need it.
jackf62
2004 - 2008 F150
Sep 22, 2009 10:11 AM
HeyMoe
Jul 15, 2006 07:52 AM
bmwfirearms
16
Oct 15, 2004 02:43 AM
merc460
Sep 9, 2002 04:15 PM
thoseapples
Jul 16, 2001 01:13 PM
