Noisy 3rd gear
Old Feb 6, 2005 | 11:49 PM
biggreen75's Avatar
biggreen75
Noisy 3rd gear
My "75" has recently developed some noise in the tranny that I can hear through the shift lever while it is in 3rd gear.
I can hear it mostly as the RPM's are rising and even more so during deceleration. All other gears are fine. Fluid level is fine.
I am ready to pull the tranny, but before I do, any input on this problem.
Old Feb 7, 2005 | 12:52 AM
Sgt_Pepper17's Avatar
Sgt_Pepper17
what kind of tranny is it. if it's a manual, check the fluid level, perhaps the gears are goin out due to a lack of lubrication.
erik
Old Feb 7, 2005 | 06:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Biggreen75.....Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Feb 7, 2005 | 09:06 PM
biggreen75's Avatar
biggreen75
Thanks for responding Sgt_Pepper17
It's a 4-speed manual, the fluid level is good. That's the first thing that I checked.
Old Feb 7, 2005 | 10:04 PM
Sgt_Pepper17
well man, my second is really loud and gets louder with the rpm increase. I filled it up with fluid but the thing won't stop leakin from around the top. the gears may be goin out anyhow from abuse from a prior owner or even you if you abuse it. It has to be the tranny and I imagine it is the internal gears.
Erik
Old Feb 8, 2005 | 12:42 AM
deerhunter3814's Avatar
deerhunter3814
Erik
My 5 speed leaked from the top where there are some rubber plugs that dry out over time, I would have to add fluid every time I changed my motor oil. I changed the fluid and put a bottle of Lucas transmission treatment in it and it stopped my leak, It has been over a year now and I have not had to add any fluid, it must soften up the rubber plugs.
Old Feb 8, 2005 | 12:44 AM
Sgt_Pepper17
mine is a cover that has a cork gasket but to get to it I would have to rip up the carpet. Not my idea of a good time, I will try the stop leak though.
Erik
Old Feb 8, 2005 | 12:53 AM
deerhunter3814
Give the Lucas a try, it is not that high and I would change the fluid when I did it.
The lucas is a treatment or stabiliser not called a stop leak.
Good luck, I hope it helps you also.
Triggh4
Oct 22, 2012 07:19 PM
Bulldawg1081
Sep 11, 2012 01:02 PM
RedBandit
44
Jun 28, 2007 07:10 AM
mongo75
Computer Chips & Tuners
Jan 10, 2007 08:30 AM
