75 C6 issues
Old Oct 22, 2012 | 06:37 PM
Triggh4's Avatar
Triggh4
75 C6 issues
1975 F150 390FE C6
I changed the fluid a few months back and the tranny was working fine before the change. Now the tranny stays in 1st when put into (D). I can manually put it into 1st and 2nd and it will comply and reverse also works. It just wont shift into 3rd gear.
The tranny has always shifted hard when put into (D) and (R) when warmed up.
When I changed the fluid I replaced the pan gasket and put it at 12inch torque. Now the pan is still leaking and seems to be leakin from the shifter and towards the torque converter area. Im talking quart size puddles.
I put a new filter in when I dropped the pan, I put lucas trans fluid in and didnt realized until i read the bottle it said "not for Type F transmissions"
Could this have messed up something in the transmission. AAMCO told me that 3rd gear had to be replaced and they would do it for $1700. I think there wrong because it wont even move from 1st gear in drive.
what are yalls opinions
Old Oct 22, 2012 | 07:01 PM
stuart1's Avatar
stuart1
Did you install the filter bolts in their proper locations?
There is 1 long bolt that could screw up the works if in the wrong spot.
The usual cause of pan leaks is from a distorted surface.
Bolt holes get pulled up.
I wouldn't let AAMCO flush my toilet.
Old Oct 22, 2012 | 07:19 PM
Triggh4's Avatar
Triggh4
im pretty sure i put the filter bolts in the same way they came out. But I cant say for certain that I noticed a bolt being longer then the rest.
can a governer or modulator be a issue?
I have vaccum to the modulator but not sure if the mod is working or not.
ah1988
Nov 16, 2010 05:58 PM
f250luis
Feb 19, 2010 04:21 AM
n5926g
1997 - 2003 F150
Dec 30, 2008 07:09 PM
azfordf100man
Aug 26, 2007 08:54 AM
pahaley_2000
Jul 20, 2005 10:40 AM
