Offroad & 4x4
V8 or I6?
Old Jan 31, 2005 | 09:58 PM
mustange70's Avatar
mustange70
I would take the e4od over the mazda tranny any day, but if you have intentions of swapping it out go for it.
Old Feb 1, 2005 | 06:22 AM
bremen242's Avatar
bremen242
Originally Posted by CrIs150
lol how about a 300 m50d and 3.08 with a set of 35x12.50 tires?? my truck pulls good and still takes off decently fast, but I can barelly spin tires in gravel.... I'd go with the 300/6.... I love mine even though I only get near 12 mpg highway.... believe me I have future plans for re-gearing....but I can still take a real steep hill in 5th gear and pull up it at normal speed bellow 800 rpm....
sorry to say- but that must be horrible.
Old Feb 1, 2005 | 07:31 AM
Icicle's Avatar
Icicle
Well, heres the only opinion I dont think youve gotten yet, I like an automatic tranny in my trucks, and I was incredibly impressed with the one inline 6 Ive driven (85 bronco) it was mated to a c-6 and did fine.
Gears can be changed. Trannys are harder to swap, go with the tranny you prefer becasue either engine can be made to be quite a stud
my .02
Old Feb 2, 2005 | 12:11 PM
highboy 74's Avatar
highboy 74
I like the 300 six and the manual tranny combo the best. I'm a huge fan of the 300 (take a look at my sig). However, I would think about swapping a 4spd with granny gear in there. JMHO
Old Feb 5, 2005 | 05:26 PM
peppy's Avatar
peppy
I have a 302 with the AOD...I like it fine.
I had a 300 with the 5 speed, liked it just fine too.
I think the 300 had more get up and go than the 302.
Old Feb 5, 2005 | 08:49 PM
74F250's Avatar
74F250
The mazda tranny isn't bad behind the inline if it is taken care of, just not geared low enough, plus it would be eaiser to swap to a zf than a older 4 speed, like almost direct bolt up. There are lenty of mods you can do to the six if you really need more power, turbos always look neat on them. I have an 85 with the np tranny and run 35's with stock gearing. It can take off jsut fine it just can't peg the 85 mph speedo any more because of stock gearing.
I have brought the motor over 4k rpm without issues tooo, damn low gears in the np tranny amke it harder to get unstck..i would go with the inline if you want to beat the crap out of it and not worry.
Old Feb 5, 2005 | 11:21 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I would do a 300-6, ZF 5speed (good HD trans, low first, OD fifth), 3.55 or 3.73 gears with stock tires, or lower gears with bigger tires. I like the NP435 and T18, but with a Six and low gears with no overdrive, mileage will suffer.
Old Feb 17, 2005 | 08:14 AM
Pkupman82's Avatar
Pkupman82
Originally Posted by bremen242
I've driven a few I6s with manuals. they are dogs.
If it has 3.55s, I'd go with the I6. All the ones I've driven have sticks w/ 3.08s [=dog].
Easy way to check- look at the axle code tag on the door. 18 = 3.08, 19 = 3.55
31s + 3.08s + 300 = total dog.
I beg to differ on that one! I am running 3.08s with 31s on my 84 F150 4wd/ 300 six/ 4 speed, if I get on it hard enough I can squawk the tires going into third gear! One time I lined up with a 305 powered Iroc Camaro at a stop light and smoked him out of the hole...of course that was with stock tires. I am planning on swapping my 3.08s out for 4.10s because I am going to a 33 or 35 inch tire. I have no problem keepin the the tires spinnin when the mud gets deep. I love my 300 it has the power right where I use it most. Don't get me wrong I'd like to have a 351 in it, the higher end power would definately be nice for towing. But a 300 will outlast a 351, the 300 is much more durable and stands up to hard abuse much better. Not only that but the 300 has a longer stroke than a 351...longer stroke = more torque!
Old Feb 17, 2005 | 06:43 PM
project supercab's Avatar
project supercab
My first truck had a 300 with 3.08 gears NP 435 and 35" dunlops' it moved, not quick but mostly driveable
new truck (77 supercab) has a 300 with a holley 390, clifford 4bbl intake,EFI manifolds and single exhaust 4.10 gear 35" tires NP 435 kicks the allmighty hiney, faster than the other truck with 5.0 EFI and 4.10's swapped in
Old Feb 18, 2005 | 11:41 AM
Schmids4.9l's Avatar
Schmids4.9l
I'd go with the 300,the average 300 will out live the 302 easily. swap that 5 speed in it though though, those are bad tranny's. aso put a steeper rearend like 3.55 or 4.10.
plus the 300 is a torque monster. doesnt have a torque curve, its more like a torque line. get the truck with the 300 and hook it up to a C-6 and put some 4.10's on it and it will be a monster!
bearcats101
24
Jun 7, 2011 04:32 PM
neverhadaford
Oct 16, 2008 07:34 AM
DMch
1997 - 2003 F150
Dec 25, 2007 08:18 PM
ech0sh4y
Dec 20, 2007 03:58 PM
2TALL
Dec 7, 2005 10:09 PM
