Offroad & 4x4
First time offroading
Old Feb 16, 2005 | 11:42 PM
Spagoo's Avatar
Spagoo
Hey everyone,
I'm about to go offroading for the first time in the desert, and I was wondering if anyone could tell me about the things I should be sure to do so I don't screw up my truck. I'm not planning on doing anything to crazy, as I just got my truck, a 2002 F150 Supercrew FX4, and its completely stock. Thanks.
Old Feb 16, 2005 | 11:51 PM
fishmanndotcom's Avatar
fishmanndotcom
yea... take it easy! bring whatever recovery equipment you can and be sure to stay with someone. dont' get brave or try to be a hero a stocker can only go so far.
remember that in sand momentum and sped is everything... i haven't done much sand wheelin but the lil bit i have done i know it can be tricky esp in the real soft stuff.
have fun too, that's the point in the sport!
-cutts-
Old Feb 17, 2005 | 12:19 AM
SoCalDesertRider's Avatar
SoCalDesertRider
Air down your tires! You'll be amazed how much more traction you have in sand when you let some air out .
Old Feb 17, 2005 | 08:35 AM
Pkupman82's Avatar
Pkupman82
Yes definately air them down or you'll be workin your truck harder than it needs to be, you'll be fighting against the sand because your tires will want to dig down. When I go up to play in Silver Lake sand dunes I like to run about 12-15 PSI in soft sand (depending on if the sand is wet or dry). With my tires aired down I can run all over the place in 2wd! It's a blast you'll love it!
Old Feb 17, 2005 | 11:27 AM
Momudder720's Avatar
Momudder720
Really, in all actuality, there are no 'roads' in sand, like there are 'roads' thru wooded areas. So you're SANDroading (just to keep the tree-huggers happy). And it's not OFFroading, it's off-HIWAY roading.
Um, yea, air down. Just make sure to bring along your handy-dandy cigarette-lighter air compressor so you can air back up.
Old Feb 18, 2005 | 12:11 AM
fomoco_1's Avatar
fomoco_1
Another very useful item to have is a charged cell phone.LOL good luck and have fun.
Old Feb 18, 2005 | 03:13 AM
Shmuck's Avatar
Shmuck
One thing about the Fords is the long wheel base. This does present it's challenges when trying to crest a dune or ridge. It takes some practice and some getting use to, but you'll get the hang of it. Definately let the air down in your tires. We will run about 15-18 psi around here. This will create a larger "foot print" (section of tire that is actually in contact with the ground) and will allow you to "float" on the sand. Momentum is definately the key to keep yourself moving. But if you do feel like you are getting stuck, whatever you do, do not hammer the trottle and end up spinning the tires. This will only act against you and making it harder to get pulled out. But getting stuck means you're gaining knowledge. Stay with your buddy, be smart, and have a good time.
Old Feb 18, 2005 | 08:38 AM
fishmanndotcom
wheelbase is what YOU make of it
-cutts-
Old Feb 18, 2005 | 11:49 AM
brokebronco's Avatar
brokebronco
-cutts-
That is true Cutts, but if you check his location......There is a LOT of sand there.
Chris
AceBronco
Bronco II
15
Nov 7, 2016 06:28 PM
racin
1997 - 2003 F150
May 31, 2016 09:00 PM
3/4ton4X4
Michigan Chapter
Aug 19, 2014 07:40 PM
bandit72577
New Member Introductions
Sep 13, 2005 05:20 AM
Tim McNutt
Sep 23, 2004 09:11 AM
