Tach Installation?
Old Jan 29, 2005 | 04:32 PM
Dave Barbieri's Avatar
Dave Barbieri
Tach Installation?
What's involved in installing an OEM tach into a truck that didn't come with one? I'd like to add that option to a 1985 F250, but not sure how ambitious I need to be.
Old Jan 29, 2005 | 07:17 PM
sa_rains's Avatar
sa_rains
Ditto!
Let me know if you find something out. I have been looking at doing the same thing. As yet, I have no answers though....
Old Jan 29, 2005 | 07:30 PM
Steina's Avatar
Steina
CO River Rat
Might be cheaper/easier to install an after-market diesel tach; you probably can find OEM tachs only at wrecking yards, plus you'll need the sending unit. If it doesn't work, you're stuck with it.
Steve
Old Jan 29, 2005 | 11:22 PM
ditch witch's Avatar
ditch witch
You'll need a sensor for tach to oerate. It's located in the IP housing, up by the oil fill cap. If your truck has a plug in the housing you can just install the sensor. If the plug is not in your housing you'll need to locate a housing with the sensor. You remove the inst. cluster and replace with cluster with tach. You may find a cluster that has printed circuitry on the pack for the tach, some may not. Either one will work. The one with circuitry requires 2 wires added to the back to go to the sensor. The one without circuitry requires 4 wires.
I replaced my entire inst. cluster. You can just replace the tach and keep your old cluster, I think. I wanted the trip meter feature on the '85 cluster so I changed the entire cluster and when I did I replaced the lights with #154's. They're about 30% brighter then #196's!
Old Jan 30, 2005 | 06:57 AM
Dave Barbieri
DW -
Thanks for the info! I kinda wondered if the printed circuit setup on the back of the IP wouldn't be the same for tach and non-tach. Sorta like all trucks having the 4WD light. Non 4WD trucks simply don't have a bulb & socket installed. The circuitry is there, the wires exist in the wiring harness, and the pins are installed in the connector(s). In looking at the schematics, I see that the wires exist in the '85 harness. I haven't checked under the hood for the connector. From your description, it seems pretty straightforward. I'll start hitting the parts yards around here looking for 'organ donors'!
I'll try the bulb swap idea. At my age, things seem to be dimming naturally, so a little extra light is a GOOD thing! 8-D Used to be, when you checked the light bulbs isle at Auto Boys or Pep Zone, there was a Wagner or GE catalog there that gave you wattage ratings. Pretty convenient for researching what you needed. Now, no catalogs and no info at the counter, either. This really helps!
Old Jan 30, 2005 | 11:57 AM
ditch witch
Dave,
The row of bulbs at the top which are for the bright lights, turn signals, brake.... don't use the bright bulbs there. Leave the #196's. You don't need that blue light shining THAT bright while driving at night. Same with the turn signals, etc.
If you don't find a tach send a PM. I got 2 when I was searching and don't need but one! I sure makes the truck more pleasurable to drive.
len
Old Jul 8, 2005 | 02:06 AM
ford350's Avatar
ford350
Where do the wires from the sensor go?
Old Jul 8, 2005 | 04:30 AM
Dave Sponaugle's Avatar
Dave Sponaugle
https://www.ford-trucks.com/user_gal...oid=50079&.jpg
My 86 had the plug for the tach sensor already there.
The wires were there to the insturment cluster in the harness.
A new pickup coil was about 60 dollars at Ford.
I only had to change the cluster and plug the harness into it, then it all worked.
If the cluster does not have a tach, it probably does not have the printed circuit on it either.
Old Jul 8, 2005 | 05:56 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 8, 2005 | 10:24 PM
ford350's Avatar
ford350
Turns out I have a gasser cluster which explains why it does not work. Back to the bone yards thanks.
Old Jul 9, 2005 | 05:32 PM
Dave Barbieri
How do you bench test a tach? It'd be nice to know if it's good before you disassemble the entire instrument panel!
Handegard
Feb 22, 2014 11:27 AM
FLJ
Electrical Systems/Wiring
May 30, 2009 04:01 AM
u.f.o
19
May 15, 2009 10:13 PM
propaneman
May 19, 2008 10:02 PM
imlowr2
18
Mar 25, 2006 10:41 PM
