Electronic Ignition for 390?
Old Jan 24, 2005 | 05:44 PM
mla's Avatar
mla
I'm currently rebuilding a 390 that has the stock points distributer, and would like to convert to an electronic, were there ever any FE's with electronic or do I have to buy a triger for mine?
Old Jan 24, 2005 | 05:48 PM
KCampbell's Avatar
KCampbell
I fitted the Pertronix II unit to mine, goes right in place of the points and couldn't be simpler. Fit and forget.
Kevin
Old Jan 24, 2005 | 05:50 PM
mla's Avatar
mla
How much $$$$$$$$$$$ ?
Old Jan 24, 2005 | 06:32 PM
banjopicker66's Avatar
banjopicker66
You can also use the Ford factory Duraspark ignition from an FE. Dissect the entire wiring harness, from a '73 - 76 with a 360 or 390, and you can install it in your FE.
Be sure to mark what wires are cut and where they go, and it will be easy to re-install.
Old Jan 24, 2005 | 09:56 PM
KCampbell's Avatar
KCampbell
I think you can pick up the Pertronix Ignitor II points replacement for around $90. I got mine from my local NAPA.
Kevin
Old Jan 25, 2005 | 02:47 AM
ford390gashog's Avatar
ford390gashog
or do what i did i bought the crane cams xr-i points conversion to electronic from summit for 74.00 with ship and it comes with rev limiter i had the ford duraspark and it is unreliable it would go through modules and pickups like no tomorrow
Old Jan 24, 2009 | 03:49 PM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
Thumbs up Pertronix Ignitor Luck
I have used three Pertronix Ignitor modules, and put over 200,000 miles on them total. If you follow the directions they work great.
The problems appear to be a lack of understanding of what a ballast resistor, or in our case, a resistor wire is and does. Again, follow directions.
But here is a new comment: after all these miles I finally toasted my module. My fault..., the original Ignitor can NOT sit there with the ignition key on while not running. The new Ignitor II can, and also is protected against hooking it up backwards. Seems like a good reason to buy the newer design for an additional $25 bucks.
My .02, Kevin
Old Jan 24, 2009 | 04:19 PM
1974SuperCabF250's Avatar
1974SuperCabF250
In my experience, the FoMoCo Duraspark outfit is fine.
Old Jan 25, 2009 | 02:20 PM
Green_Monster's Avatar
Green_Monster
hi Guys I need to slide in here and ask a question about a points conversion. I would like to go with a new distributor but for $$$ reasons a conversion seems like a better choice. Should I get or rather do I need a new coil? I have a 70 f250 w/ a 390. Petronix vs. crane as far as quality /price?
thanks
Old Jan 28, 2009 | 08:40 PM
Moto Mel's Avatar
Moto Mel
I had the OEM Transister ignition in my '67 427 cid Mercury and replaced it with a Petronix unit. The OEM unit put out one hell of a spark but suffered from point float at about 7,000 rpm, installed the Petronix unit and my ignition problem was gone.
Old Jan 28, 2009 | 10:13 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Pertronix - if you're really ****, buy TWO and put one in the glovebox
Old Feb 1, 2009 | 09:51 PM
dodmort's Avatar
dodmort
When or what year did they go from Petronix 1 to petronix II ?
i am running 4 of them....
This thought crossed my mind on a very steep slope this pm on a very rough off road drive and thinking what could go wrong at this alititude....
kevins70
42
May 6, 2017 03:02 PM
motofreek77
Dec 27, 2016 08:18 PM
greentruck72
15
Nov 26, 2016 10:01 AM
Irrational
Jan 25, 2014 06:47 AM
sixshootingexp
33
Mar 22, 2012 02:50 PM
