Offroad & 4x4
Dana 60 pinion angle (front)
Old Jan 30, 2005 | 10:55 PM
  #46
RubberDuck's Avatar
RubberDuck
Ivan, you have mail.
RubberDuck
Old Jan 9, 2009 | 04:56 PM
  #47
Henrys son's Avatar
Henrys son
Sorry to bring up old thread ,but was searching.Anyone know how much angle a rear 60 can handle .If its 20" and you just overfill,that should work ay. Does the ring gear throw oil up on the pinion bearing in the rear 60???
Old Jan 10, 2009 | 12:11 AM
  #48
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
not sure on the angles but how much lift are your running?
Old Jan 10, 2009 | 12:58 AM
  #49
Henrys son's Avatar
Henrys son
Custom shackle flip,hanger and spring lift about 7/8 inches.
Old Jan 10, 2009 | 02:45 PM
  #50
Truckin4life
on a fullsize truck?
Your pinion angle should be ok....
Ivan was running close to 14" i belive...
Old Jan 11, 2009 | 09:00 AM
  #51
mark a.'s Avatar
mark a.
A 60 front has a oil retention plate that goes on before the inner pinion bearing. You could probably put one in the rear if you were going to turn the axle up far. It's probably around .040 thick so it would be close as far as removing enough pinion shimms to make it work but it would hold the oil up in there better.
Old Feb 6, 2009 | 12:33 PM
  #52
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
haha a thread from the old days
Thisguy65
19
Jun 8, 2017 11:44 AM
Royson12
24
Jul 1, 2016 12:35 PM
KsHighboy
Jun 23, 2016 05:17 PM
Creamsicle88
Mar 1, 2016 10:10 PM
DantheMan
17
Nov 24, 2002 11:55 AM
