Fuel Inertia Switch
Old Jan 23, 2005 | 05:20 PM
KC92F150's Avatar
KC92F150
Fuel Inertia Switch
Does anyone know where the fuel inertia switch is located on a 92 F150 4X4, 4.9L F.I.. The book I have is a Haynes manual for the Bronco and Pick-up trucks from 1980-1996. It tells me that it is located on the firewall, to the left of the brake pedal. Well it's not there on my Truck . I am trying to find it so I can relieve the fuel pressure, so I can replace the fuel filter. Any help would be appreicated.
Thanks
Kevin
Old Jan 23, 2005 | 05:38 PM
trike1946's Avatar
trike1946
I think mine was inside the truck, under the dash on the passenger side, behind the side panel. I used to have a 92, but it has been awhile so I am half guessing.
Old Jan 23, 2005 | 05:47 PM
buddy555's Avatar
buddy555
On my 96 f150 it is behind the kick panel on the passenger side. You dont have to remove the panel there is a groove cut out so you can push it down. You will need to pry it up so you may actually have to remove the panel.
If you want to releive the fuel pressure just do so at the schrader valve on the fuel rail.
Old Jan 23, 2005 | 08:44 PM
KC92F150's Avatar
KC92F150
Thanks for the quick replys. I will check under the kick panel in the morning. Thanks again.
Kevin
Old Feb 12, 2005 | 05:18 PM
jbarker's Avatar
jbarker
Inertia switch
I have a 94 F-150 and can't find this switch. I've looked under the dash on both sides. Any clues?
Jim Barker
Old Feb 12, 2005 | 05:52 PM
51frrdtrk's Avatar
51frrdtrk
On the 94 the switch is located behind the kick panel on the passenger side. I never heard of pushing the switch to releave pressure. why not just push the schrader valve on the fuel rail (cover your eyes).
Old Feb 12, 2005 | 06:10 PM
jbarker's Avatar
jbarker
Sorry to be ignorant, I'm a carburetor guy. Where is the schrader valve on the 5.0? I assume the fuel rail is the hard pipe manifold feeding the fuel injectors.
Old Feb 12, 2005 | 08:12 PM
midlf's Avatar
midlf
The advantage to tripping the inerta switch, with the engine running, is no gas spillage onto the engine. Relieving the pressure at the schrader valve will spill gas on the engine, and all over. If you have a hot engine this is not good. Ford's recommended proceedure, tripping the inerta switch, appears to presume a hot engine. A good presumption at a dealership.
JBarker - Yes that is the pipe, schrader valve is on the left side of the engine towards the firewall.
900rider
Jun 2, 2005 06:26 PM
igota92bronco
1978 - 1996 Big Bronco
Dec 19, 2004 02:22 PM
LtlMsCantBWrong
Apr 19, 2004 04:47 PM
gcbriggs
Dec 9, 2003 12:17 PM
MagBayBrian
Electrical Systems/Wiring
Apr 22, 2003 08:20 PM
