94' F150 XLT Fuel Inertia Switch
My 94 F150XLT Has 176000 miles on it and decided it was going to die yesterday while I was driving a 40mph. And it will not restart. The battery is fine the engine turnes, but It doesn't seem to be getting any fuel. I was reading in my repair manual about the inertia switch and wanted to check that but I cannot seem to locate one where the manual says it should be. Does my truck have one and if so does any one know here it would be located.
Thanks
CB
Thanks
CB
Try for a red button on the firewall, basically under where the brake pedal would go if it went all the way to the firewall. That's where my '91 has it but yours might be different. I guess some have it under the plastic kick panel nearby.
You might have a bad fuel pump relay too, should be under the hood on the passenger side, just toward the back of the truck from the air filter housing, in a plastic terminal block.
dbrydon
01-05-2016 02:37 AM
FordFanatic99
Modular V10 (6.8l)
12-29-2015 09:16 PM
