1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 Superduty 2WD Wheel Bearings
Old 01-22-2005, 08:48 PM
FlyinFord's Avatar
FlyinFord
FlyinFord is offline
Alright...the last time i repalced my front rotors on my 2wd superduty, i packed the front bearings, replaced the bearing races and wheel seals and when i torqued them, i ran the the nut snug...probally to about 50lbs of torque, backed off till loose, the back to about 20lbs (roughly). So my two questions are 1) how close was i on the seating/ torquing specs, and 2) how often should the front bearings be re-packed? Currently i have about 25,000 since i replaced the rotors.
Thanks for the replys!
FLYINFORD
Old 01-22-2005, 10:54 PM
V10man's Avatar
V10man
V10man is offline
Just curious why you replaced the races and not the bearing too? I repacked mine at around 60K and now have 128k. Guess I better do it again??
Old 01-22-2005, 11:09 PM
E350_Oregon's Avatar
E350_Oregon
E350_Oregon is offline
I just did mine and the inner seal lip was just a hair too large to hold the seal. I had to tweak the seal a litlle to get it to hold. Has anyone else run into this?
I'll probably have to buy a new hub/rotor soon if the seal doesn't hold.
Old 01-23-2005, 12:28 AM
FlyinFord's Avatar
FlyinFord
I probabally should have replaced the bearings too, but at the time, they seemed to be in excellent shape while the races were just slightly pitted....any ideas on the correct torque specs???
Old 01-23-2005, 08:19 AM
bvillegator's Avatar
bvillegator
bvillegator is offline
From the Haynes Repair Manual
Step 1: Torque to 21 ft/lbs while turning the wheel in the forward direction.
Step 2: Back off 1/2 turn.
Step 3: Re torque to 18 INCH/lbs.
Just redid mine and this works perfectly.
Old 01-23-2005, 10:13 AM
FlyinFord's Avatar
FlyinFord
Thanks bvillegator!! Appreciate it!
Old 04-30-2008, 08:36 AM
Blue Collar Schollar's Avatar
Blue Collar Schollar is offline
Anyone got advise on just how to torque to 18 inch/lbs?
Old 10-23-2009, 08:23 PM
T8R's Avatar
T8R
T8R is offline
I'm in the middle of doing my ball joints and bearings tonight.
I didn't have that large a socket for my lil torque wrench - so i did a test, with the lil one set at 18 INCH.lb. It's as tight I can turn a large socket with my bare hand and greasy fingers. Clean hands got me between 20 and 21 INCH.lb
Hope this helps. :-)
BroncoRN
02-20-2017 01:28 PM
TampabayBill
10-16-2016 05:53 PM
jayro88
06-12-2016 05:13 PM
Shake-N-Bake
35
12-20-2015 07:48 PM
J.McConnell
13
04-21-2009 12:19 PM
Quick Reply: F250 Superduty 2WD Wheel Bearings
