Push button Transfer case slips into neutral from 4H
Old Jan 22, 2005 | 08:28 AM
dougg's Avatar
dougg
Over the summer I replaced the transfer case motor on my 92 f150 302 auto. Everything seemed fine when I tested 4H and 4L. The other day we got some snow so I took it out and put it in 4H, I noticed when I was not accelerating or slowing (the drive train was loose) the t-case would slip into neutral. Pushing the 4x4 button results in either a grind noises or a thump.. Then it is back in 2H and drives fine..
I never had any problems staying in 4H before I swapped the t-case motor. I would have to tap the motor to get it to engage, but once in 4h it stayed in there..
Any ideas what this could be? I noticed the mounting holes on the motor have some play, is there a way I should be aligning it? Could I have a bad motor?
I tried http://www.glue.umd.edu/~singletn/web/pages/tcase.html it used to have all the details on the trans motor, But it seems to be down now..
Thanks for any help!!!
Doug
Old Jan 22, 2005 | 11:14 AM
dougg's Avatar
dougg
Never Mind I found it.. There is a plate on the motor that adjustes the movement of the motor.
Doug
g8trowwd
1997 - 2003 F150
May 27, 2012 05:57 PM
jimjoebob99
Dec 4, 2009 11:53 AM
jimjoebob99
Dec 1, 2009 06:46 AM
NHBronco
1997 - 2003 F150
Feb 24, 2006 07:40 AM
hotrodfeguy
1978 - 1996 Big Bronco
Nov 1, 2005 09:49 PM
