Transfer case woes
Also this isn't the only problem. Yesterday while I was taking a trip out of town, I stopped at a store on my way to take the dirtbikes to the recreation area. The ground was pretty flat and when I put it into park I noticed that it rolled a little more than normal but thought nothing of it. Well when I got back into the truck and fired it up it wouldn't go anywhere. Reverse, neutral and forward didn't produce anything except some strange light clicking. When I went back to park you can hear the parking pawl try to engage and it made a lot of noise until it finally stopped. I thought that I was dead in the water. I knew that the tranny was strong and shifted good so I didn't think that was the problem. I put the truck into 4H and it didn't do anyting. I put the truck in 4L and everything locked up. I drove the remaining two miles back to where we were biking for the day. I left my manual hubs unlocked because some of the driving was on the pavement. When I got there, I put it back into 2H and everything went fine and worked like normal again. When we went to leave all seemed good till I let the truck slow down on its own (letting off the gas and the motor and tranny were draging down on the engine speed). I felt it slip again and had no power under acceleration. Luckily I was on a downhill and it locked back up right after about 15 seconds. The rest of the drive home I held a slight throttle on the engine so the drive train was always trying to go and made it home ok. It seems to me that I have a problem with the tranny output to the transfer case input or something internally wrong or out of adjustment inside the transfer case. When it's all working together, it all feels solid.
Now I haven't messed with the four wheel drive in a few months and wondered why the transfer case would be acting funny now. Is there any way to adjust the electric push button transfer case to see if that's the culprit? How hard would it be to rebuild the transfer case myself? Is there anything between the tranny and transfer case that would go bad that easily under normal driving? Would tightening the mounting bolts be the cause of my problem? I know that the case was leaking but there wasn't a visible gap between them. I would guess that it was less than 1/100". I just need to make the truck a little more dependable. Any help that you guys could give would be greatly appreciated. Thanks!
<!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- sig -->
