Sponsored by: Real Truck
05 front hitch ?
Old Jun 6, 2005 | 01:00 AM
Ford-Red's Avatar
Ford-Red
For '05 F250, I found Hidden Hitch has a front hitch around $120 that allows the fog lights to stay in-place. Installation instructions looked pretty clean. Instead, I bought LeedsEngineering for about $75. It carries 300# vertical load and uses the holes on either one of the front hooks with special strength bolts included. I plan to mount a license plate and/or step to it for normal driving. Plenty of options.
Old Jun 6, 2005 | 09:54 AM
iskybantilus's Avatar
iskybantilus
Originally Posted by Viskase1
I solved the problem by cutting a 2 1/2 wide slot in the blocker bar and welding in a 12 inch long receiver tube. Easy and cheap and seems plenty strong for use on a boat launch ramp or backing those four wheel wagons.
i was thinking same thing. i was going to put it under the bar, put a u-bolt or nut plate around it, and weld solid. got any install pics?
Old Jun 7, 2005 | 04:20 AM
Viskase1's Avatar
Viskase1
No pictures but very simple and straightforward. Don't cut all the way through the blocker bar, just remove a 2.5 inch channel of metal and weld all around. Everything stays nice and straight that way.
Old Jun 7, 2005 | 08:18 AM
Steve_250's Avatar
Steve_250
Hidden Hitch makes a front receiver. Not expensive but yeah, you'll lose the stock placement of the fogs. I know for sure you can put a 100 qt. cooler filled with ice on it, with the add-on box of course. Jetact, you already have enuf lights up there don't cha?
cnvF250
2009 - 2014 F150
Mar 8, 2012 10:30 AM
johnsjsj
Mar 26, 2008 05:55 AM
pushingxthexedge
Nov 29, 2007 10:26 AM
toypuller
Jan 18, 2005 09:36 AM
Pioneer Ford
1978 - 1996 Big Bronco
Oct 2, 2002 01:37 PM
