Sponsored by: Real Truck
05 front hitch ?
Old Jan 21, 2005 | 02:59 PM
jetact's Avatar
jetact
Question 05 front hitch ?
Has anyone either done or founda front hitch receiver for 2005 a F-350. I would like one that leaves the front hooks and oem lights if possible. Not many people list tham on thier web sites. Thanks in advance
Old Jan 21, 2005 | 03:14 PM
BFR250SD's Avatar
BFR250SD
Most of them, 99 - 04 anyways, require removing the fog lights. I know somebody pointed out a Warn last time this came up that didn't remove the lights. Haven't seen it though. As for the 05, not sure how much got changed behind the bumper, it may be the same unit. If that's the case, the tow hooks will stay. Check out Draw Tite.
Old Jan 21, 2005 | 03:47 PM
jetact's Avatar
jetact
Thanks BFR, I did look at Draw tite and it takes away the fog lights
Old Jan 21, 2005 | 05:16 PM
BFR250SD's Avatar
BFR250SD
Yeah that's the problem. Small price though for the added convienience. Not like I don't have enough light on the front of mine anyway. Anymore and I'd get complaints from the FAA
Old Jan 21, 2005 | 05:31 PM
1F350's Avatar
1F350
Either the Curt Mfg. #31014 or the warn #62524 worked on the 2004 and earlier models with the blocker beam no impact on the fog lights. I don't know if the 2005 is the same setup.
Old Jan 22, 2005 | 10:07 AM
jetact's Avatar
jetact
Thanks 1F350 there is no correct picture on the warn or the curt mfg., so Im not sure if they will work. The warn doesn't list the 05 yet. I guess I will wait a little while for the new stuff to come out.
Old Jan 22, 2005 | 02:49 PM
wolfmanagh's Avatar
wolfmanagh
I saw some that go in place of the factory tow hooks at http://leedengineering.com/
Old Jan 22, 2005 | 08:50 PM
RR 11's Avatar
RR 11
I have a ramsey on my 03 lost the factory tow hooks. Factory fogs are still in place. Had the Warn on my 96 Liked the warn better, Ramsey does not have a factory front hitch but I had a recever mounted by a local 4X4 shop
Old May 12, 2005 | 11:25 PM
aztruckn's Avatar
aztruckn
Have a look at the Bodiak Front Hitch at www.bodiak.net. Got one for my F-350. Installation was quick .
Old May 13, 2005 | 10:05 AM
PERFORMANCE RED's Avatar
PERFORMANCE RED
Cool as heck but they don't show a how they actually mount and they are e x p e n s i v e.
Old May 13, 2005 | 10:11 AM
aztruckn's Avatar
aztruckn
They actually mount to your exisiting front tow hooks. They are bit higher in price but they install quickly and do not interfere with your driving lights or license plate bracket. I like how it was designed to fit my F-350.
Cheers,
Nick
Old May 13, 2005 | 10:26 AM
PERFORMANCE RED
Cheers,
Nick
HOW do they mount to the two hook? It looks like it slides over the top of it but how do you secure it to the hook?
Old May 13, 2005 | 12:27 PM
iskybantilus's Avatar
iskybantilus
yea, i was wondering same thing myself. also, the load rating for vertical load on those tow hooks cant be much.
Old May 13, 2005 | 04:15 PM
keith58's Avatar
keith58
hitch
It looks like there are holes to install pins just like normal rear hitches
Old Jun 1, 2005 | 10:05 PM
Viskase1's Avatar
Viskase1
I solved the problem by cutting a 2 1/2 wide slot in the blocker bar and welding in a 12 inch long receiver tube. Easy and cheap and seems plenty strong for use on a boat launch ramp or backing those four wheel wagons.
