Sponsored by: Real Truck
Speedo Calibration
Old May 9, 2005 | 10:07 AM
Axemant31's Avatar
Axemant31
Speedo Calibration
I was wandering if anyone had info on speedometer calibration for an 05 F250 Lariat? I put some larger tires on and now all that handy information on the digital readout is inaccurate.
Old May 9, 2005 | 10:43 AM
jetact's Avatar
jetact
I didn't go up to much on tire size but would also like to recalibrate my speedo
Old May 9, 2005 | 11:07 AM
Bagger's Avatar
Bagger
Check it with a gps. My speedo with stock ATs is about 2 miles per hour too high ( showing 55 on the speedo is really 53 on the GPS). I know my jeep was dead on after going up two tire sizes.
Old Jun 6, 2005 | 12:04 PM
hoser343's Avatar
hoser343
The Ford calibration equation is:
20186 / tire height in inches = some number, then: some number /.6666 = program code
Example:
Start with 20186, divide by actual tire size in inches. Divide again by .6666
You want to use a rolling measurement to get your actual tire height (If you try to measure the tire in the driveway, use conversion charts, or anything else you will end up with an inaccurate reading again). Use your rear tire since the sensor is located there. Mark the ground and your tire and roll forward 3 times marking the ground each time. (I ran over a spot of oil at a local gas station and measured between my tread mark prints), then divide that number by three to get the average length of one revolution (this will protect yourself against a bad reading using just one revolution). You can then divide the length of one revolution by 3.14 to get actual tire height. Be careful in your measurements, a small amount will change the code. EX: 31.69" tire height is code 956, and 31.21" tire height is code 970.
Now, to program it into your truck:
Warning: You can only change the calibration 6 times without replacing the module.
To set the calibration, ground the single wire connector under the glove box it says PSOM (Programable Speedometer Opdometer Module). ”Yes there is only one and it has a spade type plug on the end". I used a wire with clips on both ends to ground the plug to a screw under the dash or try a test light and use the clip end to the PSOM and the other jam in a dooe hinge. Now look at your speedometer on the face of your dash while sitting in the drivers seat and there should be a "reset" button and a "select" button. While holding the reset button in on the trip meter, turn the ignition to 'on' while the wire is still grounded. Let go of the reset button. The speedometer display will sweep once and will show a code of some kind then push in again the "reset" button and the existing code will be displayed with RECAL?, mine said 976 RECAL? Now you enter your new code you came up with by dividing the rolling measurement by PI or 3.14 by pushing the "select" button until it gets to the new calibration code number. You may have to push “select” a whole bunch of times until you get to your code. If you turn off the key at this point the original code will not be changed or any of the 6 lives will not be used. To store your new code press “Reset”. Turn off the key. Unplug the ground wire. To check the new calibration, use the mile markers on the interstate. Run an indicated 60 mph and it should take exactly 60 seconds to go 1 mile.
Old Jun 7, 2005 | 07:36 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome hoser343, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 7, 2005 | 08:12 AM
Steve_250's Avatar
Steve_250
Does this speedo recal work if you only need to have the speedo and odometer read correctly? I don't have the overhead thingey. I know that at 30 mph my speedo reads 1.3 mph slow and at 70 it reads 2.2 slow. This is with a stock truck.
Mine is NOT a digital readout on the speedo but is on the odometer.
Old Jun 7, 2005 | 09:07 AM
superrangerman2002's Avatar
superrangerman2002
Example:
I'm not so sure that this will work on the SD trucks. I have seen it done on the OBS trucks with the digital odometer. Problem is that not all SD trucks have a digital odometer untill the newer years, and even then I'm not so sure that it will work.
fusefinder
Nov 28, 2014 06:31 PM
5 Star Tuning
Vendor Specials, Discounts, Product Announcements & Group Buys
Jul 7, 2010 07:48 PM
Fluid Power
Computer Chips & Tuners
Jun 12, 2007 08:30 PM
dynarider1995
Nov 15, 2006 03:16 PM
jsandlin
Nov 9, 2006 04:58 PM
